Engine idle problem
Old Sep 21, 2002 | 07:13 AM
ETHYL's Avatar
ETHYL
Default Engine idle problem
With the A/C on, auto trans remaining in Drive, and stopped at a traffic intersection,the engine starts to "miss"and RPM drops below idle for a few seconds,then returns to normal idle RPM for a about 30 seconds or so then repeats the miss until I start to drive away. The problem does not happen if I move the selector to the "N" position, or A/C turned off in Drive or N. No problems during normal driveing with A/C on or off.
Have you experienced this problem and what did you do to correct it?
Thanks in advance,
ETHYL
94 Admiral Blue Coupe
Daily Driver
No mods
Old Sep 21, 2002 | 08:02 AM
jimbo10494's Avatar
jimbo10494
Default Re: Engine idle problem (ETHYL)
My 87 Coupe does the same thing. I have tuned it up, replaces wires,cap, plugs, removed and cleaned the throttle body, set the TPS. No codes are showing. What is next?
