3.54 gears
3.54 gears
I recently installed 3.54 richmond gear in my dana 36
I bought to summit
1.- 3,54 gears
2.- speed sensor 10456089
3. speedometer drive gear 15t
4.- speedometer driven gear 43t
but 43t gear came incorrect
where can i buy this part ? 25513050 - Driven gear, 43-tooth (purple)
I bought to summit
1.- 3,54 gears
I bought to summit
1.- 3,54 gears
I bought to summit
1.- 3,54 gears
I would think that by now with nearly NONE of the VSS driven gears being available it's much easier and likely less expensive to use a DRA to accomplish the speedometer correction. I've done mechanical corrections for years and a DRA was a last resort. I'm out of NOS early VSS and I've got maybe 5 NOS gears but NOT a 43 tooth that I believe should be purple.
Depending on where you're located you could visit some older transmission shops and ask! I know a shop that actually specialized in speedometer correction and they usually had a couple dozen "on the shelf". He's long time passed!
DRA and if this is a C4 you would use it with what's already there and resell the parts you bought!
Digital Ratio Adapter - The one most often mentioned here on the CF is a Dakota Digital. It has the more attractive pricing.
http://www.dakotadigital.com/index.c...rod/prd126.htm
I had always avoided DD because years ago many had issues with the SLP - Firehawks etc with them.
I have used Abbott in the past but they're priced quite high today. They use ERA terminology. This is a link to their product and support page.
http://www.abbott-tach.com/era.htm
Eduardo L98 1991 (01-27-2017)
I changed my wheel size and needed to change the driven gear, super had to find those things.
I did some searching via ebay and finally found the gear i was looking for.
http://www.ecklerscorvette.com/corve...1984-2004.html
its a good option
but I only need a gear 1 of 3 that I need to replace, I dont believe that nobody sells this part ?
please to all people to replace this`part, please let me know where can I found it
a lot of webpages says that sell this part but nobody have in stock
thanks in advance
its a good option
thanks in advance
You might try Performance Automatic Transmission Center: https://transmissioncenter.net/home/
I installed a 3.54 gear in my 93 with the 700R4, and they had the Drive and Driven Gears that were needed. I hope this helps.
Link dont works
Patc ?
if is PATC I sent an email past monday and I dont have answer, past year I bought the parts for 3:07 gear and the same as Summit I received the gear with stem
With the Speedometer Calibrator you do not need the purple gear in order have an accurate speedometer with the 3.54 gears. You use whatever gear you have and the calibrator will compensate for the 3.54 gears.
if I cant found it, then WVZR-1 or your option will be the way to go
Still I dont believe that I cant found this purple gear, the caprice have this gear as oem
Contact your local Chevrolet Parts Depart. and ask them to check the Chevrolet Vintage Parts database for both the Corvette and the Caprice. As with any hard to find part, be prepared to pay a lot of money if it is in the Vintage Parts database.
The electrical connector '90 and earlier is center of, '91+ it's on the outer diameter, there's an offset to accommodate driven gear diameters that are different for gears less than 40 tooth count and 40+ tooth count. There's offsets for both center and outer diameter connector VSS.
Eduardo L98 1991 (01-28-2017)
if i remember correctly exist a chart in the forum of vss, gears for diferent years and rear end, I cant found it.
please, somebody can post the url
thanks in advance
thanks in advance
Here's one that is generally accepted as correct but I do believe that there's errors. I don't recall the errors right now but I did note a few many years ago. The VSS mentioned for '91,'92 & '93 A4 with a 40+ tooth count needs to be ignored for sure.
Do you have a specific question?
http://garage.grumpysperformance.com...-adapter.1237/
From that link there's also KHasting's calculator - for the 3.54 ignore the VSS reference - your choice will work
http://webpages.charter.net/khasting...peedocalc.html
What is your tire size? You actually need to use "rolling tire radius" for calculations but close is close.
If I had 15 & 42 I'd use them.
Is the 3.54 already done? If yes install what you've got tomorrow and go for a ride with a GPS - post back tomorrow evening with comparisons.
3.45 is already done
2.56 speedometer setup is broken,
3.45 speedometer setup is incomplete only have gray and vss
i ask about the green gear because its availble oposed as purple ( available to me for about 30 days)
tire is 25.50
i supose i will bought this green gear until i found a purple one
tire is 25.50
