Runs but to restart later will not run
Ok 1988 Vette all stock replace fuel tank and filter, ok start car no problems run down highway great pale it for hour go to start will not start and smell fuel bad pull plugs all wet with fuel, wait couple of days will start then same problem wait hour will not start and plugs soaked with fuel HELP !!!
Use a scanner to see if your ECT is reading correctly. It can cause a hard start when warm due to flooding the motor with to much gas.
Also after letting it warm up, shut it off and try to start it again but keep the gas pedal floored and see if it starts, obviously If it does start immediately take your foot off the pedal.
When it doesn't, also try pulling the MAF and see if things change.
Leaky injector or fpr I would pull the vacuum line of the fpr and smell for fuel. Look at your oil for fuel as well do not want a grenade.
If fuel is in the vacuum line, then the engine is being flooded after shutdown which will make it hard to start in the morning.
If that the case, get another new FPR and do an exchange.
Have a critter chewing?
