Turbo 5.3 swap build
i take it you wont be using the factory digi dash?
I think you will be okay with the D44 as long as you don't dump the clutch with a high RPM and sticky tires.
I have a ProCharger to install-Just trying to learn about the tuning first. Then will install it. Will also be running it on e85.
Good luck with your build and thanks for posting!
Steve
Impressive build Svante!
Hope you will show at Mantorp in August for the annual CCS track meeting- we need more fast C4s!
I will have to fabricate an intake elbow for my blown C4 so Im interested to learn more about your intake plenum box. What is the wall thickness?
I´d love to go to mantorp, but its about 700kilometers away so by that time i have drained Sweden on E85
I try to have it ready with the turbos in place and dynoed until the 20´th of May, then they will run test and tune up here in north.
Sure ask away, you could send a PM and we can take it in Swedish
/Svante.
Cool project Svante, Whats the specs on the BW S366? T-4/74mm turbine 0.91 a/r turbine house?
Going to be cool to see where you put the turbos. I was thinking about trying the twin BW S366, but the one's with the 90 deg elbow built into the compressor housing.
That intake you built at home was a pretty sweet piece. Congrats.
The turbos are BW 177281 0.88A/R single entry T4. The plan is to have them installed in a 45deg angle in front of the motor ( each corner ). I have moved the radiator/intercooler package towards the front of the car to make room for the turbos. The new radiator/fan cover is also slimmed down to make more room. On my old motor gen 1 355ci i ran a single S475 in front of the motor ( there is a build thread here at Corvetteforum ). But i think this will be a better setup and the turbos are further away from the radiator.
/Svante
Very cool buddy, I was thinking about running the BW 177284 turbo.
I've run them as a singles on 5.9 cummins trucks. They spool pretty decent and make awesome power.
What S475 you run? I also was considering the S480/T-6 96, just cause I have one. Curious on how it ran in the car? I want a hard hitting turbo, as when the turbo came to life I would know it.
Just left overs from previous builds.
#33
/Svante
The following 3 users liked this post by Svante:
#36
Sure I would like to see what ever pictures you have. What you think about the lenco transmission? I didn't even think about using a lenco. Curious on hearing what you say. I'm not sure on which transmission I want in my car right now.
#38
/Svante
Mike Holmen (04-26-2017)
#39
Wow very nice build. The new 5.3 is going to be a killer build. Wow I'm impressed that there are decent C4 LS turbo builds on this forum. Keep the new pics coming.
You going to use a dual inlet and single outlet inlet intercooler. Looks like you can weld aluminum pretty decent.
#40
/Svsnte
