TPI Kicking My Fanny
1) "Electronic Spark Control Module ESC (in fender)
2) "HEI Module" in distributor
also- "Electronic Spark Timing (EST) Distributor" which refers to the distributor plus the HEI Module.
However, when you try to order these parts, the aftermarket switches and confuses the names. You have to go by their pictures. I ordered the "ICM" from one vendor which is in fact the ESC.
Anyways.... I suspect the entity inside the distributor... the HEI Module or as we all affectionately call it the ICM.
I should have ordered the ICM instead of the ICM. Pun intended.
No scanner required to check codes, just a paperclip or jumper wire.
http://www.corvetteforum.guru/module...post_id=248955
The ESC in the fender well area is what monitors the knock sensors in the block and transmits that to the ECM to retard timing when there is detonation.
What are the actual fuel pressure values? Key on and running.
Here is another thought:
Did you verify top dead center when everything was apart? I mean mechanically by pulling the #1 spark plug? The reason I ask is because the harmonic balancer on these can separate at the rubber portion and allow the outer timing ring to slip. That will give false values for setting timing. Happened to me personally, that's how I know.
I think it's the HEI Module.
1) Ground
2) +12 Volts
3) Knock sensor
4) ECM
Aside from that...Don't become fixated on one piece that may or may not be the issue.
I'd still like to know the following:
1) Specific fuel pressure values key on and running
2) Coolant temperature sensor resistance value and air temp
3) If TDC was mechanically verified and if distributor was set correctly based on that. One tooth off can cause running problems.
TDC was verified at the gears and at the distributor with a valve cover off.
It runs great 1100-1900. If the mechanics were off, this would not happen.
I just pulled this from my notes (spreadsheet): "ECU fan switch 2500 +/- ohms @ 74 deg F measured"
The measured data point falls squarely between expected:
3400 ohms at 70F, and 1800 ohms at 100F
#34
"the bulb is burnt out, circuit is bad, or you have a bad ecm"
Once I get it running and inspected, I can fart around with that.
This car has been grossly abused. TLC will come after the bandages are off. LOL
It's very contrary to my normal approach, but I'm gonna just throw parts at it until it runs.
I even have a 1966 points distributor in the wings if I have to.
I'll dig up a new HEI module first.
#35
The values you posted look good.
Back to the codes - that's the first thing I'd be inspecting. Car doesn't need to run to test the circuit/values. There is a troubleshooting chart in the FSM.
If it were my car, I wouldn't do anything else until I verify the ECM is good.
#36
This will be my last port in the storm.... it's a big ticket item. I have no way to test the one I have.
Just checked my orders... I have a new coil, a new ICM, and a new ICM ordered.
Ha Ha... the HEI Module and the ESC Module are BOTH listed as the "ICM" by the parts vendor.
#37
I rebuilt one of my old Accel HEI distributors with a new 2 wire HEI module, new cap, new rotor, and new coil. A duplicate of this distributor is in my carbureted 86 Silverado where the 4 wire connector to the ECM is just dangling in the engine compartment. I have been driving this truck like this since 2000. So, I thought maybe I could get away with it here.
No go. The renegade distributor functions perfectly and provides the correct spark. But.... the injectors won't fire. I tested this by removing the MAF tube and spraying starting fluid into the throttle body. The engine fired right up.
So to answer my original question.... no. You can't just drop in a "1 wire" HEI distributor to bypass the OEM electronics. You won't get any fuel from the injectors. Case closed.
New HEI module & ESC will arrive in a few days and I can start from scratch. If they don't fix it. I'll order a ECM. If that doesn't fix it, a new carburetor.
#38
2017 C4 of Year Finalist
Had a similar issue, was the Ignition Control Module. It's a cheap part and easy to replace, they go bad from heat often, and a big sign that they're going out is the problems get worse when the engine is hot. (IE-won't start until the engine is cooled off)
Do you have a Factory Service Manual? If not I'd highly recommend one, lots of good diagnostic info in there. It'll keep you from throwing parts at it.
#40
