Auto trans fluid change-Tips/suggestions?
Filter seal is part metal,part rubber, did you get the metal part out? It is a seal not just an o-ring. Auto Zone loan-a-tool for inch pound torque wrench.
Changing trans fluid at 4000 miles is waste of time-money, manual intervals are severe service 15,000 miles, normal service 100,000 miles. Just draining pan only gets out 1/2 of fluid or less. Just suck out fluid thru dipstick, About 3 qts. at a time 2 or 3 times run car between doing and then drop pan and service for a more complete fluid change.Torque pan bolts to 97 in/lbs three times is suggested
