bypass oil pressure/fuel pump switch from ecm.
Cruising
I straightwired fuel pump from battery... ground already existed. mounting an on/off switch. car has no hopes of being restored. but, I swear, it wll not be a parts car. Runs great this way. what do u think? Purest be nice please...
If the fuel pump fuse and the fusible link are good, replace the fuel pump relay and the car should start up without the band-aid. I'm no purist but repairing the issue is more dependable and easier to do than dragging wires. What year model is it? Fill out your profile, we can be more help.
avoyer (04-20-2017)
..... Safety ... in the event of an accident or a mechanical malfunction , will you be able to turn the fuel pump off before you get incinerated ? .....
Cruising
bypassing both relays/switches 89
Cruising
If the relay is clicking, then you have a good staring point there.
Check if you have power feed to the relay (orange). If not then run a new power line to the relay.
Next step is to check connection from relay to fuse and fuse to pump.
If you want to bypass everything after the relay then you could add a new fuse and wire from relay to pump and still keep all safety.
I used a cole hersee 24059 constant duty solenoid when I bypassed the oem fuel circuit on my carbed 84. . Run your 12v wire from the battery (through a fuse or circuit breaker) to one of the big studs on the 24059. Attach the wire going back to the fuel pump to the other large stud on the 24059. Run a wire from an ignition on source( I used the hei pigtail to splice into) to one of the two smaller studs, either one . Use the remaining stud to run a ground wire to a good ground. I installed a Ford inertia "crash" safety on/off switch used on their fuel pump circuits and wired it into the ignition on the wire from the hei splice. I also installed a toggle switch in the engine compartment on the ground wire on the solenoid as an anti theft device or for shutting off the the fuel pump for other tuning reasons.
