1985 how difficult is it to replace shift seal on Tranny
https://www.corvetteforum.com/forums/c4-tech-performance/1909666-replacing-700r4-shift-linkage-seal-any-advice.html
BWD111 (04-26-2017)
It's easy if you have the tool. 10 minutes tops, once the car is in the air. I don't think the exhaust gets in the way. Need about 3" clearance from the seal to the exhaust for the tool. It can be done without the tool, but requires removing the pan and manual linkage, lever and shaft.
