84 Adding Comp Cams 12-230-2
Replacing factory cam with this one. Should I replace springs as Comp Cams says?
Factory cam: Duration @.050 202/206
Lift: 403/415 Lsa 115
Comp Cam: Duration @.050 206/212
Lift: 432/444 Las 110
WOGI (05-03-2017)
I'm fishing for info, trying to learn how tolerant the ecm on the cross fire engine is to camshaft and other engine changes. I want to run my cross fire injection system, looking for answers of what needs to be done to it to run on a 9to 1 383cid engine with good flowing heads and headers. Looking for advise on cam selection that this ecm will run with that is better than the stock cam profiles. I know that the ecm prom can be changed with one that has modified perimeter's not trying to jack your tread hear, just seeking advise
Pro Mechanic
OP, I probably wouldn't change springs for a cam that mild, but most would probably disagree with me. I'm cheap and like to push things. If you get valve float, you can always go back and change springs later.
WOGI (05-03-2017)
