HVAC Fault Codes 01 and 02 on 1993 Corvette hatchback. No heat or AC
my 1993 corvette AC stopped working. Was fine for the year I've had it. Now no AC and the heat won't work either. Had never used the heat before so don't know if that is new or not. ran diagnostics and found two faults come up. 01 and 02 faults. Both refer to Temperature Door Motor Circuit Fault. Ran diagnostic parameters number 24 and 34 . Door position is 128 deg and dosent seem to move on any other tests. BAD motor?
