door light bulb change
jdmtra (05-21-2017)
Thank You, great post. I was able to unscrew the 2 Philips that hold the light in . The problem wasn't the bulb. The ground wire that connects to the light switch was not connected. I didn't want to disconnect the door lock in fear of breaking something. With a little persuasion, I was able to get the black center piece loose after moving the section near the armrest first.
I see you updated your bulbs to LED - good move. my halogens got so hot, they melted the plastic housing. bought an 8 pack of LED's on fleabay for around $7. good mod -
I did the same thing, the LED bulbs also fit under the hood in the two lights there, take less power, provide more light. Quick, cheap and easy fix. When taking the glass covers off the engine compartment lights, make sure they don't drop... they make a big mess when they splat on the floor!
The following 2 users liked this post by Sid.123:
428CobraJet (03-10-2023),
Joe C (05-21-2017)
