1991 l98 Service engine soon
Old 05-22-2017, 08:22 PM
rattle trap
8th Gear
rattle trap's Avatar
Default 1991 l98 Service engine soon
Along with the service engine soon display, I get a sys appearing in the speedo display. the speedometer reads 0 at any speed, and the cruise control doesn't work. it also won't idle. This has been intermittent for a while, and is now constant. any ideas?
Old 05-22-2017, 09:13 PM
aklim
aklim's Avatar
Received 2,214 Likes on 1,928 Posts
Vehicle Speed Sensor? Any way you can scan it to confirm if the ECM is seeing any speed reading?
Old 05-22-2017, 09:30 PM
rattle trap
8th Gear
I'm afraid I don't have the equipment to do that. I can only do basic maintenance.
Old 05-22-2017, 10:36 PM
aklim
aklim's Avatar
Maybe an Autozone has a scanner? If you are keeping the car I'd get one. You will need it sooner or later.
Old 05-22-2017, 11:41 PM
rattle trap
8th Gear
Thanks, I'll be looking to buy an OBD1 scanner tonight.
Old 05-22-2017, 11:47 PM
aklim
aklim's Avatar
Make sure you get a scanner and NOT a code reader
Old 05-23-2017, 12:06 AM
rattle trap
8th Gear
I ordered an OBD1 reader a few minutes ago. It was only $24, but you're saying that's not what I need. I didn't see any scanners for 1991 gm. Any suggestions on where to buy?
Old 05-23-2017, 12:11 AM
aklim
aklim's Avatar
Snap on MT2500? What you got is a code reader. A $24 paperclip. I can do it with a paperclip if all it does is tell me what code is present.
rattle trap (05-23-2017)
Old 05-23-2017, 12:34 AM
rattle trap
8th Gear
thanks
To 1991 l98 Service engine soon
Quick Reply: 1991 l98 Service engine soon
