Transmission fitment question
Old 05-26-2017, 10:02 PM
phucking-low
phucking-low's Avatar
Default Transmission fitment question
I have a 84 corvette and I have the chance to purchase a 6 speed transmission from a 1990 corvette for cheap. Will this 6 speed transmission bot to my L83 350 in my 84 corvette? I can have a drive shaft made no problem. Guy has a complete 4+3 and complete 6 speed manual from c4 corvettes. I have a slow build project 84 corvette I want to swap my automatic to manual.
Old 05-27-2017, 04:04 AM
armybyrd
armybyrd's Avatar
yes sir!
Old 05-27-2017, 04:33 AM
JoBy
JoBy's Avatar
It is the same work to convert to either 4+3 or 6 speed.
Go for the 6-speed.
Old 05-27-2017, 07:59 AM
phucking-low
http://members.cisdi.com/~anesthes/zf6/
On this write up it refers to 86-88 years, will this be the same as my 84?
Old 05-27-2017, 08:14 AM
s carter
s carter's Avatar
Go for the 6-speed.
The Six speed may be Easier, Both will have their Challenges under the Dash & under car. But the Six your not Making a tub well to get and mount the Shifter in, instead your cutting a Well placed hole. Plus some other parts covered by the Previous Post.
Old 05-27-2017, 09:50 AM
WVZR-1
WVZR-1's Avatar
Received 2,258 Likes on 2,021 Posts
If you buy the ZF 6-speed you need to be sure you get the clutch housing, fork etc. Pedals, master etc are pretty well covered but be sure to also gather the "spacer" used master to firewall since you're doing an A4 to a MT
Old 05-27-2017, 04:02 PM
s carter
s carter's Avatar
Originally Posted by ihatebarkingdogs
I'm not going to bother to look these up, but:
Is the console top panel the same for a 4+3 as it is for the 89 6-speed?
Is the 6-speed shifter in exactly the same place as the body-mounted shifter?
Is the floor tunnel the same shape?
Is the C-Beam the same for the 6-Speed and 4+3?
To answer your question Not much is the same, see the links that I did pull up.
Truthfully given today's Automatic Transmission, Other than personal choice there is no big advantage or Disadvantage between and in some cases auto's are a little better with no lost Acceleration while shifting.
But if you want a Manual car Buy a Manual car Making a Apple Into a Orange will always have it's Problems
https://www.bing.com/images/search?v...verlay&first=1
https://www.bing.com/images/search?v...x=1&ajaxhist=0
Old 05-27-2017, 08:28 PM
phucking-low
I know it would be easier to buy a manual car, but this corvette is important to me and absolutely can't let it go.
Old 05-28-2017, 07:54 AM
phucking-low
Is this the drive shaft yoke that is needed for this transmission swap
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Or If this one will work its a lot cheaper
http://www.dennysdriveshaft.com/p369...ts_corvet.html
Old 05-28-2017, 08:44 AM
WVZR-1
WVZR-1's Avatar
At one time Denny's was selling a T400 32 spline yoke as a fit for the ZF and it AIN'T - it will insert BUT IT AIN'T right! A very good drive-line shop told me that a T400 fit about as well as a "BEAT UP 100K MILE" - Have they actually corrected that? They don't mention the spline dimension so I'd be doubtful but maybe.
*** Sonnax part# is for a T400 and other 32-spline but NOT the ZF
Do people use the T400 spline spec? Many likely have
There are less expensive alternatives.
I'd buy neither of those!
This thread read post#27 through to it's end1!
https://www.corvetteforum.com/forums...al-leak-2.html
Old 05-28-2017, 08:51 PM
phucking-low
Ok one last thing, does the 1984 700R4 starter work with the 6 speed transmission or do I need the 6 speed starter.
Old 05-28-2017, 09:55 PM
WVZR-1
WVZR-1's Avatar
You need a 'denso starter from an '88+ car
Did you understand the slip-yoke thread?
Old 05-28-2017, 09:57 PM
phucking-low
Do I need one with the offset gear reduction?
I keep thinking of things will my 700r4 transmission mount work on the 6 speed? The thread I am going by is converting a 4+3 to a 6 speed so I am unsure is the 700r4 trans mount will work on the 6 speed
Old 05-29-2017, 02:18 AM
JoBy
JoBy's Avatar
Manual and automatic use different length C-Beam and driveshaft between transmission and rear axle. That is because of different rear axle. Your exising C-Beam should fit with manual transmission.
Old 05-29-2017, 07:31 AM
phucking-low
Thank you, so what about the starter do I need the one with off set gear reduction?
Old 05-29-2017, 08:06 AM
JoBy
JoBy's Avatar
From googling pictures the stock 1984 starter probably does not clear the ZF bellousing. Not a big problem. Use another starter or modify the bellhousing.
Old 05-29-2017, 08:25 AM
phucking-low
I am not going to use the 84 starter, I am going to buy a starter from a 1990 corvette same year the transmission I got but there is two starters to pick from a standard one and one that has offset gear reduction. Which one do I need?
To Transmission fitment question
Old 05-29-2017, 08:42 AM
WVZR-1
WVZR-1's Avatar
I would be looking for a "used" that still had the OE/GM label on it and then rebuild it which is generally very inexpensive. Less than $35 generally buys everything needed for a 'denso "tune-up". I'd post a "wanted to buy" here on the CF maybe.
If you're looking to an "off the shelf" buy something that will reference these OE #'s 1998578 or 10455702 or 10455709. Any that have these same three #'s on them could maybe be considered OE.
Where are you located?
C-beam length is dictated by rear differential. D36 is one and D44 different.
Old 05-29-2017, 09:35 AM
phucking-low
I plan to get a off the self one, but again do I want a offset gear reduction or no? Or can you tell me what off set gear reduction is and does and why is it an option.
I live in Ohio
Old 05-29-2017, 10:08 AM
JoBy
JoBy's Avatar
Stock 1984 starter has the motor in line with the drive gear.
With offset ger reduction you have the motor beside the drive gear and a reduction gear between them. This type uses a smaller lighter motor with more rpm. Typically all aftermerket ministarters are this type.
Quick Reply: Transmission fitment question
