1989 C-4 Cooling Fans
Main fan was not working changed out relay all good. Now both main and auxiliary fan always running? I do not believe this is correct? Solution please?
Received 1,596 Likes
The main fan is controlled by a coolant temp sensor (between cyl#1-3), it should come on @~225 deg, while the other comes on @ ~235 deg or whenever the A/C is on.
If you have an auxiliary pusher fan in front of the AC condenser it is controlled by coolant temp switch found between cylinders 1 & 3 in the drivers side cylinder head. It comes on @ ~238*F and off @220*F. The aux fan temp switch between cylinders 1 and 3 shorts to ground at 238 F! This grounds the aux fan relay coil and turns the aux fan on. The ECM turns the main fan on at 228 F and off at about 210 F. The main fan is turned on by the ECM based on inputs from the coolant temp sensor, vehicle speed sensor, and the A/C coolant fan switch.
Are you the original owner?
The aux fan is controlled by a coolant temp sensor/switch found between cylinders 1 & 3 in drivers side head. Is it permanently grounded? You sure the aux. and main fan relays are good?
Replaced both relays new.
OP - it seems apparent that there's been a modification done to the fan wiring.
Do you have the FSM for your car? It should be easily enough researched.
Received 1,400 Likes
No that's not correct for an '89. The main fan is controlled by the ECM it comes on when the coolant temp sensor hits ~228*F and off @ ~210*F. The Coolant Temp Sensor can be found below the thermostat housing.
It appears they have been both wired together and grounded all the time to make them run. This is actually detrimental to cooling once you get up to speed, and will eventually burn out the fan motors.
