86 c68 hvac --- what does this rear defrost blade terminal plug into?
Oil Producer
hi guys you were looking at the blade terminal at the bottom of the driver side hatch strut. There is no wire on the car that looks like it fits onto this. The other side of the car has the power coming in from the harness and it looks like the current flows in from the passenger side up, aling the strut, to the passenger side window, along the filament, then comes off the glass on to the driver side strut, along the strut, .....then....i dont know.
is it supposed to go to ground on the frame?
Where does this terminal plug into?
I have searched, no dice.This is on my 1986 that was clearly take it apart by somebody and then put back together by somebody else who did not know where things went. My guess is the previous owner bought a project and reassembled the car and I have affectively disassembled it and put it back together correctly.
what plugs into this blade terminal??
Oil Producer
[img]webkit-fake-url://be926b2d-53ac-48fa-8fef-52e43acc5f73/imagegif[/img]
Thnx Cliff!!! ill build a cable and ground it to that location.
