89 Coupe Passenger Window Not Going Down
Passenger window suddenly will not go down? I can hear a faint click when trying to go up or down but could not feel anything while my hand was on the motor. Is there a solenoid or a relay in the door or did the motor just go out?
If the window goes down the Motor has a Dead spot and needs Repair/Replacement and you can keep car whole until Parts are Found.
If not pull the door panel and test Circuit.at the switch and motor.
No Relay
How can I get the window to go down manually? Looks the like the motor and or regulator needs to be replaced. I also have to remove the window so a scratch free replacement can be put in.
