hard to swap the reverse switch on a 4+3?
Oil Producer
Hi everybody, I have a 4+3 and I have diagnosed my no-reverse/rear marker lights issue to a failed reverse switch.
Is this something relatively easy to do or do i need to pull the slave cylinder as i read the zf owners are required to do?
I also ready that the detent ball typically gets a groove in it and one quick fix is to rotate the detent ball and it will possible be a short term fix until the replacement arrives in the mail.
thnx.
thnx.
thnx.
thnx.
it is nowhere near your Clutch, The Reverse switch is by your Reverse shifter arm on the O/D Unit Adapter Plate
Oil Producer
voila!
thanx very much!
I believe a 7/8" crows foot wrench on a long 3/8" extension will get the job done. It's kinda tight around the reverse light switch.
Oil Producer
perfect thanx guys! got a set for xmas and havnt used them yet.
