Which battery for an LT4 GS?
Leeds.io
St. Jude Donor '14-'15-'16
Hey all. Can someone please give me a specific part number of a battery that will properly fit in a GS? I did searches for 96 LT4 battery but the replies were "red top, sears, die-hard 9, optimus prime"...etc and when I Google those things I get a million possibilities. I called the local autopparts store and they said they didn't have any batteries for a 1996 Corvette. I know the terminals need to be on the side but is there a specific size to look for when shopping for a new battery? I'm new at the battery swap obviously.
Help!
I'm looking for replies like "model 2395257 from Sears will fit like a glove and has enough CCA for the LT4"
Thank you very much!
Best,
Gene
Help!
Best,
Gene
A GROUP 75 battery with as many CCA as you can afford will do you well. Brand and model might change from each but if you stick to a GROUP 75 specification you will be fine.
ac delco
Help!
Best,
Gene
Help!
Best,
Gene
phantasms (06-15-2017)
When I replaced mine last year, I got one of the "Everstart MAXX" batteries from Walmart. Had the highest CCA and one of the best prices of all the ones I looked at other than the gel batteries. It's worked just fine for me, and my daughter has one also.
These batteries are made by Johnson Controls. Battery brands with the same values (CCA) are basically the same battery.
As posted, buy the battery with the most CCAs, that fits your vehicle, at the lowest price.
I have found that Costco offers the best value in batteries, but their selection may be limited.
Help!
Best,
Gene
Help!
Best,
Gene
For wathever stupid reason, Delco seems to work. She, give you everything you want. Boom boom long time. The Batteries Plus and whatever doesn't have the longevity.
Yes but to what spec? You don't think that it is simply a matter of sticking a different label do you?
I do private labels. Same factory, same ingredients, different concentration. More money, more good stuff and less filler. Less money less good stuff and more filler. Bag is same size but we put whatever name you like.
LT$ battery
Help!
Best,
Gene
Help!
Best,
Gene
Sledge78
phantasms (07-03-2017)
