84 Rear speaker connectors - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 06-16-2017, 11:12 AM   #1
Adam2980
Junior Member
Default 84 Rear speaker connectors
I am redoing the sound system in my 84, and the guy who owned it befor me already put in an aftermarket system (long time ago) and I am trying to utilize the factory wires. In the rear speakers, there is a four wire connector. I was wondering if anyone knows what two wires are just for the speaker or if there is an adapter plug or connector out there. I appreciate any help. Thanks.
Adam
Adam2980 is offline   Reply With Quote
Old 06-18-2017, 06:32 PM   #2
JoBy
CF Senior Member
JoBy's Avatar
It is for the Bose active speakers. 12 V Power, Ground and two signal cables from the stereo.
JoBy is offline   Reply With Quote
Old 06-19-2017, 12:25 AM   #3
Patsgarage
CF Senior Member
Patsgarage's Avatar
Just a FYI, the signal wires from the head unit are not designed to carry power to the speakers. If you are using an aftermarket head unit you should run new wires to the speakers using the correct gauge wire.
Patsgarage is offline   Reply With Quote
Old 06-19-2017, 01:05 AM   #4
ihatebarkingdogs
CF Senior Member
Quote:
In my 85, the signal wires to the Bose speakers are the exact same gauge and type of wire that is used for 'regular' speakers. The factory Bose wire will work just fine for an aftermarket unit.
ihatebarkingdogs is offline   Reply With Quote
Old 06-19-2017, 01:12 AM   #5
Patsgarage
CF Senior Member
Patsgarage's Avatar
Quote:
Will it work ? Sure, but so will plenty of other things that should not be done.
Old 06-19-2017, 06:07 PM   #6
ihatebarkingdogs
CF Senior Member
You're wrong about the Bose signal wires. They are not "different" than wires for speaker-level outputs on aftermarket radios. 25 watts into 8 ohm speakers is 1.76 Amps. Well within the capability of the .8mm wire used for the Bose signal. No reason "not to do it".
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 84 Rear speaker connectors
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    ignition timing Adam2980 C4 Tech/Performance 6 07-29-2017 06:34 AM
    90 Convertible Wiring Question - Corrosion Sucks! adamsullivan44 C4 General Discussion 2 07-07-2017 05:41 AM
    Front speakers not working Adam2980 C4 General Discussion 0 06-16-2017 05:34 PM
    Sensor ID'ing Adam2980 C4 Tech/Performance 3 12-14-2016 10:06 PM
    Speaker connectors sargeter Audio/Electronics 6 04-15-2016 01:54 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
