113 heads on a late 86/87
Or see if the part number for the exhaust manifolds changed? It appears the parts houses list the same exhaust manifold gaskets for both heads.
I suspect that if anything has changed, you will likely only need to open up the manifold exhaust ports if they are smaller than the ports on the head.
