Air cleaner duct retaing knob
Air cleaner duct retaing ****
How do I remove the air cleaner duct retaining *****. The two on top of the air cleaner duct. Do they just pull out? I tried to turn them but they barely move. Thanks
On my 86 they turn CCW and are actual threaded screws at the ends, not a bayonet type. Sounds like yours are gunked up or rusty. The bolts below the ***** are 2-3 inches long.
The two ***** I'm referring to are the ones on top of the duct. I had no problem with the two ***** down in front that hold the air filter housing and have the long threaded screw on the end. These two ***** have no threaded screw protruding from them. The pictures I have looked out for the air duct ***** show them with a knurled end around the bottom like they would push in.
Yes, this is the **** I'm referring to. They don't seem to turn like they're screwed in. I don't want to pry on them and risk breaking something if that's not the right way to get them out. Hope you can enlighten me on this.
St. Jude Donor '17-'18-'19-'20-'21-'22
They screw on just like the ones for the filter housing except there are studs coming up from the top of the radiator shroud housing. There are spring clips that hold the studs in place below which may start turning, if so you may have to keep sliding it around to get the studs out of the holes. The ***** do screw down onto the studs.
I just did this last night. I used a really thin putty knife and slid it between the radiator housing and the airduct to stop the spring clip from spinning.
don hall (06-23-2017)
I also used a very, very light coating of silicone grease (pure, laboratory grade) on the **** threads. DO NOT USE any petroleum based or aerosol products on the plastic, and definitely not WD-40.
finally, do not over tighten the ***** - lightly hand tight will suffice -
don hall (06-28-2017)
Thanks Joe C for your help. The pop rivet is a great idea and the picture was worth a thousand words. My problem was on a show car that the air cleaner had never been removed in 32 years! The ***** were stuck hard. I figured they should twist off but I became really stumped when everything started turning with one of the *****. Not knowing how this assembly came off I didn't want to put a lot of pressure on and risk breaking. When I finally got them loose, thanks to everyone here, I saw the problem. The indent tab was barely punched thru allowing the whole spring clip to turn. I punched it out correctly but will also add the pop rivet as extra insurance.
the only problem I see with that is now, the stud-clip does not float within the radiator shroud, but is in a fixed position. to rivet into the shroud as shown, very careful measurements would need to be made, so the air filter housing is in perfect alignment for installation. my method is better since the stud-clip floats a bit as originally designed -
