Is this a knuckleheaded fix of an AC evaporator?
I was going to add some Freon to my 93 and I see this.
What the hell. Is that evaporator meant for a an Impala or something???
If I move the expansion tank, the AC fitting flexes.
This cannot be factory.
Any C4 AC experts in the Denver area?
Received 1,596 Likes
That looks like a 134a fitting, I am not sure when GM changed over the C4, but if your car was originally charged with R12 then it was probably converted at some point.
How hard is it to dig into the evaporator box?
Does anyone have any suggestions?
I know I can unmount the exp tank & put in Freon, but I suspect the fitting leaks due to all the vibrational stress it sees. This can't be right.
Don't trust the web, there should be a sticker under the hood with the type of refrigerant and amount of the charge. If your car was originally 134a than a PO could have installed an aftermarket evaporator.
look around for an electrical connector plug laying around in the vicinity of that r134a adapter.
here's a pic of my 85 - your 93 should look similar -
and, to answer some of the OP's original questions, the 93 corvette originally should have been R12, and from the looks of it, it looks like the correct evaporator core.
these may help - https://www.corvetteforum.com/forums...or-93-lt1.html
https://www.corvetteforum.com/forums...vice-port.html
https://www.corvetteforum.com/forums...nt-1992-a.html
I believe the question is about the flexing of the refrigerant line, not the operation of the a/c. The a/c has apparently been working okay.(?)
Looking at these two photos, the difference is the missing insulation between the a/c line and the housing. That would allow the a/c line to wiggle! I had the same problem on my '84! A chunk of foam weatherstrip stuffed in this area solved my problem. This missing chunk of foam also resulted in a cold air discharge (leak) from the a/c housing in my car. Cliff Harris noticed this missing insulation in my car during a recent get-together! Thanks, Cliff! ( I hope you're doing okay, Cliff!)
Thanks Joe.
I checked again and it looks like 93 was the last year for R12 Freon.
Looks like I have a really bubbauped system. Put in an early evaporator and then added on 134a Freon and maybe patched in a wire to make up for a lack of the pressure switch.
I will check the can area at the front of the engine for the stock fill port.
More on this tomorrow.
Thanks Joe.
I doubt you have a Bubba'ed system. I really doubt someone smart enough to do a 134a refrigerant upgrade would eliminate the low pressure switch! The system wouldn't work right without the switch. There's some reason the 134a fill port is in that unusual location. I'm sure you'll find the l/p switch.
But I will say: only a bubba would install an AC fitting that is touching another component in the engine bay.
Looking at some of the photos that have been attached of the Earlier year cars makes me wonder if he has one made for something like an 86
I'd think that before the OP goes about insinuating it was done by Bubba or his cousin he might think about his "inspection" before purchase. I'd thought this might have been questioned before money changed hands. I can't imagine most overlooking it. It could be a very well thought out approach to a repair. PO might know - maybe a very experienced C4 guy knew "just what to do"!!
we really need to see the big and complete picture, especially that electrical connector, and if there's an actual LP cycle switch in the system, but with first impressions, something's not right. whether it been "bubba'd" or not is another thing.
too many unanswered questions. the OP needs to supply more info...
maybe - ??? - I don't know. I would think if there was sufficient Freon in the system it would not throw a code. if high and low pressures were within proper operating ranges, the ECM would see everything as normal.
The high pressure switch is just a safety, if the system is operating properly it should never come into play.
There are two basic configurations for the evaporator. Early with the fitting pointing outboard and later with it pointing inboard. It gets a little sketchy as some catalogs show one and some show the other for the later type. 4 Seasons shows the wrong part. If you look at Rock Auto they have both ways shown.
I have a new evaporator here with the fitting pointing outboard from 4 Seasons. I've had it sitting here forever and don't have the original box anymore but I think I got this for a later C4 and obviously didn't use it.
That 90 degree fitting is very a very typical part. My guess is that someone got this all together ran into this problem and moved the transducer to the accumulator to make it all work. I'm just not too keen on the elbow up against the expansion tank but I guess it worked this long. I guess we'll see...
when I converted my 85 from R12, I purchased a (non-adjustable) LP cycling switch that was designed or pre-set for R134a operating pressures.
edit: we may be talking apples and oranges here. i'm assuming we're talking about the low pressure cycling switch, and you my be referencing the (high pressure) A/C refrigerant pressure sensor. that appears to be some sort of a transducer feeding a (variable) electrical signal back to the powertrain control module. if that's the case, sorry for the confusion.
