LT4 Hot Cam kit Help
Old Oct 1, 2002 | 05:57 PM
kspurr's Avatar
kspurr
Default LT4 Hot Cam kit Help
I am already planning to install a meziere water pump, and while I'm in, I may consider some more work, specifically the opti and an lt4 hot cam.
What are the benefits/implications of installing the lt4 hot cam kit on a '95 6 speed vette? The motor is currently at approx 94,000 miles. Is there any tuning required or the addition of a chip?
Old Oct 1, 2002 | 06:28 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Re: LT4 Hot Cam kit Help (kspurr)
The idle will need to be redone to be smoother. Ed Wright can do it all, and it will make a difference. Theres more than just the idle with Ed, Like driveability, Top End etc. Over all, my friends Grand SPort needed a Recal of the computer, and after having it done, it was much better, even though the idle was the only thing he thought he needed, as the factory was a little low rpm wise. SO, Ed did his and it was a new beast. Mid twelves on BFG KD's, factory gearing and no headers. Not Bad.
The Meizer is another topic, I have only seen one on a friends, and he loves it. Do the OPTII while you have it off, dont skimp on this part. Steve
Old Oct 1, 2002 | 06:34 PM
vader86's Avatar
vader86
benefits will be a gain of 30-40hp
But you will need the reprogramming done or the engine will not make optimum power and the idle wont be smooth.
Old Oct 1, 2002 | 10:07 PM
kspurr's Avatar
kspurr
Default Re: LT4 Hot Cam kit Help (vader86)
Hmm, I'd love to go with the hotcam and get some tuning done, but I may have to wait on that. I still need to get my rx-7 in for some dyno time...
Old Oct 1, 2002 | 10:24 PM
kspurr's Avatar
kspurr
Where is a good place to buy the lt4 hot cam kit? Does it come with everything needed? How much should I expect to spend if I get it?
Old Oct 2, 2002 | 12:26 AM
vader86's Avatar
vader86
GM sells it, should be about the same price everywhere, but i would call Jeff Kopp at Superior Chevrolet, his number is in a thread somewhere on this page.
It comes with pretty much everything you need i think. Its only a few hundred.
To LT4 Hot Cam kit Help
