Horn don't work
i am NOT familiar with the horn circut but i would suspect carefuilly prying off the button (if an early c4) and checking the contacts for surface corrosion would help.
cheers
cheers
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Or the connector at the base of the steering column
there are a ton of threads about horns with many helpful suggestions.
I have the same issue and have checked some of it, just need the time to pull the airbag out.
Do a search in the top right, be sure to put " " around a string of words if that is what you are looking for, and you should see some trouble shooting tips to figure out the issue.
Good luck.
Good luck.
