On a 84 vette question on BS ON REAR STOCK WHEELS
On a 84 Vette with stock wheels , anyone know the backspacing on the rear wheels, I know they are 16x 8.5 , just need backspacing in inches
I didn't measure, but 8.5" should be +32mm backspace and 9.5" should be +38 mm backspace. Should be molded into the backside of the rims. WVZR-1 is most likely right on measurements in inches, don't think I've seen bad data so far from him.
Well let's consider the math! You first need to measure "Total Wheel Width" - A very general assumption is that TWW is the advertised width +1". So 8.5 +1 = 9.5 / 2 = 4.75 + 1.259 (offset) = 6.009 The math for a 9.5 should yield maybe 6.746 - round up or down?
Back-spacing when used in tire/wheel fitment needs to be calculated measuring by the user. It certainly be different wheel to wheel.
