Dumb question-what does knock sound like?
2017 C4 of Year Finalist
knock sensor and pigtail is pretty cheap I'm sure, and like I said it looks like it's crap anyway. I might go ahead and replace before too long, but I will try the good gas first.
since I have half a tank of crap already, what do I do? Fill it up with the good stuff? add seafoam to what I already have?
well all this caused me to go looking out on the web. unplug and replug the knock sensor(s) and get some good gas. you were probably going to get some good gas anyway.
start with the least expensive first
if the knock sensor is failing, it wouldn't throw the code 43, right? Or is that faulty logic?
I would cut off the old pigtail and put a new one in place. Twist them together and solder the wires. Shrink wrap them. Some coolant will come out when you take out the KS.
If you suspect the gas, I would suck it out and put fresh premium gas in it. I never recommend the snake oils but they got to get money out of customers.
I was also thinking of changing the spark plug gap. I bought .045 gapped plugs, but recently found out that after the car was released the spec was changed to .035 for my engine. Should I re-gap my spark plugs?
I've also ordered a new knock sensor and pigtail. They're cheap and mine have probably needed to be changed for some time now.
I may be seriously overthinking this but I don't want to have to worry about knock and ruining my engine.
Got time to do a coolant flush since you are going there?
If the gap is too large, I don't think it will knock. Misfire, possible since the spark might not be able to jump the gap. KS will remove knock till it can't anymore. How is the compression?
Bfenty (08-03-2017)
I would just for peace of mind.
Curious, why would I do a coolant flush? I have flushed the system previously. Just not sure how it would affect knock. My engine stays nice and cool so I doubt there is an issue there...
haven't checked compression super recently, but I did when I was working on my misfire and it was good all around. I doubt it has changed.
If it is within 2 years and you reverse flushed the system through the KS to wash out sediment, you just need to top off the coolant loss.
Bfenty (08-03-2017)
Bfenty (08-03-2017)
When I do my flush, I lay under the car and send water into the KS hole and let it flow out. Repeat several times till happy. Later on I also remove the hose for the oil cooler and do the same. Suffice to say, I do this as last thing of the day, hose myself off, dry up, go inside and take a shower.
Location: Las Vegas - Just stop perpetuating myths please.
Just a good time to learn tuning your car. Yes get some good gas and a maintenance manual for your year vette. Learn how to set base timing. When you master that look into a real time scan which requires a scanner (used OBD I) or a laptop with the correct cable and software. Then you can really analyze your engine.
Good luck.
Good luck.
Bfenty (08-03-2017)
Good luck.
Good luck.
#33
Here is a link to a how to a Video it's a pretty basic
https://www.youtube.com/watch?v=LgMYsU-Xivk
#34
http://m.autozone.com/wrenches-pliers-and-cutters/wrench/duralast-2-pcs-distributor-clamp-wrench-set/914110_0_0?cmpid=PS:3:3:1&s_kwcid=AL!514 2!3!193278490474!!!!296346273086!&ef_id= WP5ulAAAAd3yu8nn:20170803185749:s
#35
Here's a video i took this morning or a short test drive. You can hear the sound it's making when I hit the accelerator a little harder, the clicking sound.
#36
Can't hear a thing. Maybe it would help to shoot the tach so we can tell what you're doing.
#37
Hmmm...in the original you can hear it clearly. Youtube seems to have removed audio for some reason?
EDIT: the original audio is back. from 4-6 seconds you can hear a clicking sound when I hit the accelerator. That's what I'm talking about.
#38
So get the Car off the ground enough to get under and with a SOFT Mallet or the Heel of your hand hit the Y Pipe Starting by the Bend by the Manifolds and work your way back. If my Hunch is Correct you will pick up the Rattle about 6 to 15' from the bend. if you hear let me know and I will tell you a quick a Cost free repair
#39
is it a Metal on Metal Buzz When Expectorating, In 84/85 we had a Bit of a Problem with inner walls of the Exhaust Pipes Separating it would make a Rattle/Buzz that would make you crazy to hear and drive Nuts to find.
Update to the overall situation-put Lucas Octane Booster in and about 8 gallons of 93 Octane fuel from BP. I figure the Octane Booster would help, even if it's only a little bit, and since the tank is now half 93 Octane, it's probably a lot better octane overall in there. Still getting the rattle under load.
#40
Pro Mechanic
Have you seen the thread where I posted pics of my intake valves?
