Pwr antenna doesn't retract, motor runs briefly
anyone have experience with replacement antenna mast
1990 Base Coupe.
Finally happened. Shut car off in garage today and antenna stayed up. Motor ran about the normal amount of time to retract and shut off. So it appears the motor is fine. It cycles up and down, but no antenna movement.
I found a replacement antenna at mid america
http://www.mamotorworks.com/Corvette...-1992-601242-1
Anyone have experience with this? Seems easy enough assuming there are no plastic parts from the old antenna roaming around in the motor.
solved
With the mast replacement from mid America, it was as easy as it looked. Hardest part was carefully removing the grommet. Works like new. Came with contact spring and wrench for the antenna nut.
Wish I had seen your post earlier.
Mick
