general question about 84 interior vs 86
Oil Producer
there is a guy parting out an 84 near me and he is giving me dibs on interior panels and trim panels. its the same color as mine inside (med. grey).
my trim panels around the hatch and the arch over the head are deformed in my 86 and i'd like to buy them and replace them with these parts if they fit.
also, the kick panel under the passenger side, with the light and the vent, i'd like to source these from this 84 if possible as well.
anybody have a sense of which parts are compatible inside?
I dunno what all you are after, but I have pretty good luck using the part numbers to determine year and fit for stuff like that..
Here's a good source:
http://keenparts.com/pages/catalog2.php?cat=116&year=C4
Cluster trim panel will not interchange.
The '86 cluster was angled differently to try to help cut glare in bright sunlight. Engineering moved the bottom of the cluster away from the driver approx. 1/2".
The '1984-85 trim will leave a gap between the bottom of the gauge displays and the trim opening in a 1986-89. The 1986 will not fit into the 1984-85 dash.
Jonathan.....
Jonathan.....
Oil Producer
thank you jonathon.
is that the only interior part that will not interchange?
there some different door handle pulls on the very early 84's i think but other than that are they interchangeable?
There will be trim differences between the years but they should interchange. You would need to change out both door panels.
I have an acquaintance who has an '84. I'll try to get over to see him this weekend to look at his door trims.
Jonathan.....
Jonathan.....
I recently discovered that the AC control panel is different. 1984 is a one-off year, and it uses a different A/C control panel. 1985-89 use a panel with a faceplate that you can replace, those will not work with the 1984. Also, I think some of the markings for seat / mirror controls may differ slightly between '84 and '85-89.
Oil Producer
lets keep ths thread going. chime in with differences as discovered. so many 84's out there being parted out.
Greetings.
I got the pics of the '84 door trim along with pics of my '86 door trim posted.
The gist is that the soft trim should interchange w/o any problems; the difference is in the inner release handle and assoc. parts.
The electric lock switch is a '84 only switch and the release handle is different so the metal attaching plate with the map light would need to be changed out to the '84 soft trim or the entire door panel should work.
Hope this helps.
Jonathan...
Hope this helps.
Jonathan...
