Heads & Cam time (LE2) opinions
I should get my heads and intake back in a couple of weeks and I had some questions/recommendations on supporting parts. The car is a '96 A4 with 3.07 gears, I plan on 3200 Vig TQ and shift kit.
I was able to clarify the 48mm vs 58mm throttle body from Lloyd (earlier thread). A 48mm is fine for my application, a 58mm would perform better after 5K+RPMs.
Here are supporting parts recommended by Lloyd:
Lunati rocker arms
https://www.summitracing.com/parts/lun-15345-16
Lunati pushrods
https://www.summitracing.com/parts/lun-7034-16
Lunati Timing chain
https://www.summitracing.com/parts/lun-92128
Trickflow injectors
https://www.summitracing.com/parts/tfs-89030
They all look like good options and I was curious about the injectors, I've seen post about a vendor who sells rebuilt ones. Should I look into those or are the new trickflows good.
Thanks in advance for your input and opinions
P.S. - so excited, long time coming
Lunati rocker arms
Lunati pushrods
Lunati Timing chain
Trickflow injectors
Location: Las Vegas - Just stop perpetuating myths please.
Lunati rocker arms
Lunati pushrods
Lunati Timing chain
Trickflow injectors
Lunati rocker arms
Lunati pushrods
Lunati Timing chain
Trickflow injectors
Well you really need a reprogram/tune for your new combo. And if you change injectors it will be manditory just to keep the engine running. Myself I would begin with stock injectors and dyno tune with those first as you can easily increase the fuel pressure with a bolt on adj regulator and make corrections for injector pulse width in the tune - rather than spend for expensive injectors.
Make sure you check rocker arm and p-rod clearances when you assemble the valve train. Rocker arms need to clear the valve spring retainer and the p-rods need to move smoothly in their guide slots (whatever you use) and not drag.
Hope this helps and let us know how it all works out.
vette196 (08-11-2017)
Lunati pushrods
Lunati pushrods
