1991 corvette 350 engine.
Step 2 Spark, Does it have Spark after it shuts off. If you turn Key Without bringing it back to Off position just re-crank Does it have Spark? And while cranking does it have Fuel Pressure
If you have the The Pressure and the Spark, Check Fuel Condition Draw off a Sample from Bottom of tank into a Clear glass jar see if you picked up some water.
