Performance rear end??
Have a 95 and cant figure out if it has the performance rear end, someone just told me if thiers a corvette emblem on the seats then it does have it.. we checked some numbers around the car but couldn't really find any thing that pertained to the rear end
In this post is a '95 SPID with G92 and G44, performance axle and 3.07 ratio. If your '95 is an A4 then maybe expect these or likely GM1 which would be 2.59
https://www.corvetteforum.com/forums...post1592006786
Received 1,400 Likes
Look for the RPO codes that start with "G", that will tell you. G92 by itself means different things in different years, but basically means nothing.
Its the other G codes that tell you what the gearing was from the factory.
where would you find out what gear ratio it is too?
there will be a label such as this that will have the codes on it. you might have to look for the label, then you look up the RPO codes
Where could my stickers be?
1993 I looked under the rear hatch on Pass side. Just jack location sticker.
Never could get drivers side open. Traction control is there I think.
I have 2 unreadable stickers on drivers door edge.
Haven't found mine yet.
'93 is on the center console lid. Unless it's been removed or the lid changed it should be there. Check the VIN to be sure it's for the correct car and not a replaced lid from another.
did I miss something or does anyone know what the exact G92 "Performance Ratio" is?
answer: 3.453
answer: 3.453
The combination of G92 and G44 RPO codes provides the performance rear end. Test drove a few C4s before buying mine and I can easily tell the difference in throttle response between the two. As long as the car is fairly stock.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
My 95
you mean the car comes unglued when you nail it?
I have a 95 coupe with an auto and a RPO code pointing to a 2.59 ratio. I am having a 3.54 ratio installed. what should I expect in performance?
If your car is stock or close to stock, you should expect to have a completely different/improved urgency during acceleration. It will provide more performance than most other performance improvement. One of the biggest bang for the bucks.
jgalfo (08-21-2017)
