'94 C4 A/C code Re Set
I got the "09" Low Refrigerant Code when I did the code read on my '94 C4. The system has since been evacuated and recharged and is now holding correct pressure.
I am still getting the same code when I check it...how do I clear the trouble code?
Pull the AC Programmer fuse easiest I'd think. Has the car been driven and does the compressor cycle "as expected" or does there still seem to be compressor issues?
Yes car has been driven and compressor runs all the time...90* South Florida heat and humidity...no compressor issues.
