Swapping my Dana 36 for a D44
Old 08-15-2017, 11:39 AM
Rohn
Rohn's Avatar
Default Swapping my Dana 36 for a D44
I was told that my D36(1984 manual) can only be replaced with a D44 unless you replace the half shafts and yokes? IOW a 1984 36 replacement requires a 1985-1987 D44. I understand that the batwing an TQ arm also are not interchangeable with my D36(no issue there as sellers will supply those.. So this limits my search to those years. Is this correct?
Old 08-15-2017, 01:23 PM
bjankuski
bjankuski's Avatar
Any dana 36 will fit in, the 1988 and newer just require the larger bolts and modifications to factory bolt holes for the control arm (make them larger) or bushing installed in the dana 36 to make the bolt holes smaller and use the original hardware. The Dana 44 will require the same modification from 1988 and later along with the driveshaft and torque arm.
Old 08-15-2017, 03:11 PM
Rohn
Rohn's Avatar
Dana 44 is going in. I understand your comments. However I was told the 88 and newer requires 88 and newer half shafts and yoke. Is this true? Are the internals of a 88 and newer D44 different than 87 and older D44?.
Thank you/
Old 08-15-2017, 05:53 PM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
Thank you/
A half-shaft has a 1350 u-joint on each end, the short-axle is part of either the D36 or the D44 and the spindle is part of the suspension unit each side. A half-shaft will swap between any year C4, it's not D36 or D44 specific.
This is a half-shaft #6, there are steel and there are aluminum. They will swap.
Old 08-15-2017, 08:08 PM
C409
C409's Avatar
Dana 44 is going in. However I was told the 88 and newer requires 88 and newer half shafts and yoke. Is this true?
Thank you/
..... No ! .....
Old 08-15-2017, 08:13 PM
Mike Holmen
Mike Holmen's Avatar
I'm debating on doing the same swap. How much money you got into it so far? Vette dana 44 are pretty pricey for what you get.
Been considering instead of the dana 44, I been thinking of running ford 9in 35 spline irs in my car? Its very similar money to the dana 44. I'm probably going to do this upgrade this winter.
I have an warmed up LS 6.0L engine swap and 700R currently in a 85 vette.
Old 08-15-2017, 08:27 PM
C409
C409's Avatar
..... Bolts right in ? .....
Old 08-15-2017, 08:51 PM
Mike Holmen
No you just have to build your own bat wing for the dutchman ford 9in.
http://www.dutchmanaxles.com/irs-hou...oke-style.html
The next weak link with be the axle hub output shafts ends. I haven't found any upgrades there yet. Would be nice if someone makes a billet 300m output shafts for the dana 36/44?
Old 08-17-2017, 07:43 AM
C409
C409's Avatar
..... Let us know how that works out for you ... take lots of pics ... particularly interested in how it compares cost-wise to swapping in a D44 .....
Old 08-17-2017, 09:45 AM
Mike Holmen
Its going to be my winter project this year and next. My current dana 36 bat wing is leaking pretty bad right now in my car. I was hoping on getting a few more miles on it prior to ripping everything apart. I'm still not sure on what transmission I'm going to run. I really want to install a tremec six speed, but my bank account says 700r
I'm not much for taking pictures.
I'm going to build my own c beam, the factory unit was pretty flexible. I reforced the ends quite abit which bolts to the transmission and rear end.
To Swapping my Dana 36 for a D44
Quick Reply: Swapping my Dana 36 for a D44
