'87 conv Interior lights won't shut off
Old 08-23-2017, 09:23 AM
bearfan1985
8th Gear
bearfan1985's Avatar
Default '87 conv Interior lights won't shut off
My battery has gone dead twice. I had it checked by autozone they said the battery & alternator are good. Drove it home, next morning did not start again. Completely dead. Put battery charger on it again, but the interior lights are staying on and won't charge. The interior lights were working OK last week and the car took a charge. Is there a manual shut off somewhere so I can at least get a charge and get it to the shop. I tried pressing the door lights, they click and shut off, release it they come back on. I'm a non-tech girl so if I need to do any fuse thing or whatever, I won't. I may just have to have it towed in. Thanks
Old 08-23-2017, 08:32 PM
djpink889
djpink889's Avatar
By door lights do you mean the black trigger on the door? If so they are adjustable. Gotta look closely and you'll see a spot where you can stick a small flathead screwdriver or the like and pry out the pin a bit. Shouldn't take much. Obviously be careful because they are plastic. I had that problem not too long ago with the trigger in my hatch.
Old 08-23-2017, 10:28 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
pull the CTSY fuse and see if battery stays charged
Old 08-24-2017, 02:20 AM
VikingTrad3r
Oil Producer
VikingTrad3r's Avatar
Received 2,262 Likes on 1,446 Posts
yes pull ctsy (coutesy lights) fuse and then boost. that should get you to shop
cbances are its the interior light delay timer that you need to replace.
To '87 conv Interior lights won't shut off
Quick Reply: '87 conv Interior lights won't shut off
