Water pump replacement parts list??
The water pump has started to leak. While I am there I am going to replace the timing cover seals. I hope to do it in a day so I am ordering the parts I will need. The belt, tensioner, idler, hoses, plug wires, and thermostat, coolant flushed and knocks have been done. It's a 95 w/70k, mn6. Any thoughts?
Here's what I am thinking:
Water pump
Water pump coupler (probably grooved)
Timing seal set
Opti cap and rotor
Thanks Gary
Water pump
Timing seal set
Opti cap and rotor
Thanks Gary
Water pump
Timing seal set
Opti cap and rotor
Thanks Gary
Water pump
Timing seal set
Opti cap and rotor
Thanks Gary
http://www.ebay.com/itm/N1-J-39089-T...EAAOSwPhdVIUmA
yd328 (09-04-2017)
Plugs and plug wires... obviously, you dont HAVE to do these, but while youre in there, might as well... Not sure what your coolant hoses look like as those may be worth a check too. I think LT1 water pumps come with the T-stat and housing also IIRC
yd328 (09-04-2017)
