My 85 Z51 is all over the road between hard shifts. Bushings?
Old 09-04-2017, 09:58 PM
Greg MFn Z
Support Corvetteforum!
Greg MFn Z's Avatar
St Jude Donor '14
Default My 85 Z51 is all over the road between hard shifts. Bushings?
When I shift gears aggressively , the whole car shifts sideways a bit. feels loose and sloppy. I don't know the first thing about which bushings effect what, or which I need to change. What kit should I purchase and what should I expect to pay in Labor. I am not a DIY person.
Old 09-04-2017, 10:23 PM
xrav22
xrav22's Avatar
After I changed all of my bad bushings in the rear I still felt a little jump to the side when going over a bump. I searched for months and it was the lower shock bolt stem which was slightly loose, wow what a rattle. The strut bushings need to be taken apart to see them, but the camber Bushings, trailing arm bushings and rear sway bar ends are all culprits. Now I have a very tight rear suspension and I did not do the batwing bushings yet.
Good luck
BV85 (09-04-2017)
Old 09-04-2017, 11:38 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Check your alignment too mic the rear thrust angle is odd, your car will jump sideways on acceleration.
Old 09-29-2017, 12:17 AM
Greg MFn Z
Greg MFn Z's Avatar
St Jude Donor '14
Drive it again today. It's not just aggressive shifting , but normal shifting. It's almost too dangerous to drive. What bushing kits should I be buying to tighten this car up?
Old 09-29-2017, 01:22 AM
xrav22
xrav22's Avatar
It is hard to say when I bought mine I took the wheel off and had no sway bar bushings at all. So I changed them. Have to have a look in there . The only ones you cannot see at all are the strut rod bushings. They are behind the bolts. Replace as needed I dont think a kit is much of a savings. I used the red poly and the grease no squeaks yet.
Here are a few pics from my 85
You have to start wiggling so you know what to replace 1st.
Old 09-29-2017, 04:27 AM
gerardvg
gerardvg's Avatar
Hi
The bushes can only be checked when removed from the car,
its not as easy as you would expect.
Perhaps get a 4 wheel alignment done before spending a weekend replacing all the cars bushes.
My tips are cut the outer rubber away, use a drill and drill holes through the rubber for easier removal with a vice and sockets.
I did notice the suspension seems 30% stiffer and more "bouncy"after replacing all the bushes, they don't make rubber ones anymore
that is the down side. the prothane bushes are a tight fit that resist suspension movement .... even with the special lube.
I am eyeing some Banski trailing arms with spherical rod ends that do not restrict suspension movement, cant stand the bouncy feel.
See link below
http://www.ebay.com/itm/C4-Corvette-...19.m1438.l2649
I already have the banski rear spindle / camber rods for precise camber adjustment that doesn't move over rough roads.
The movement you are experiencing is most likely the spindle rods /camber rods, they were shot on my c4 with 170,000 miles.
The trailing arm bushes were ok but had a few cracks, i regret having replaced the rubber bushings with prothane ones because of the harsh ride afterwards....
Old 09-29-2017, 05:53 AM
hcbph
hcbph's Avatar
Add another vote for the Banski Suspension package for enhanced handling requirements on a C4. I've put them on my 86 last year and it's made a world of difference in how my car handles on those windy country roads.
Put them on, get a 4 wheel alignment and you'll be amazed on the difference in handling.
To My 85 Z51 is all over the road between hard shifts. Bushings?
Quick Reply: My 85 Z51 is all over the road between hard shifts. Bushings?
