4L80E Swap - Let the Games begin
Old 10-03-2017, 08:22 PM
  #41
Pwnage1337
Pwnage1337's Avatar
Originally Posted by 89L98TPI
For those who are following I recently swapped a 4L80 in in place of my built 700R4. BUYERS BEWARE! Even with the Billet tail housing we needed to shorten the driveshaft and cbeam to make it fit. Loving the results so far. Good luck with your swap
For your cooler lines, did you use regular 90 degree AN fittings?
I have 90 degree fittings, but the rear line is pretty tight to the tunnel. The trans actually needs to drop a tiny bit in my car which should give me a bit more space. I was researching fittings and there are "Banjo" style that would give tons of clearance, but they are $45 just for the fittings.
Curious what others have done. There is plenty of room near the front, just the rear cooler line will be close.
Old 10-03-2017, 11:10 PM
  #42
89L98TPI
89L98TPI's Avatar
Yes I used 90° fittings for hose ends to attach to trans. The rear was real close to tunnel. Exhaust needed some torch and hammer work but it all fit snuggly...
Old 10-03-2017, 11:14 PM
  #43
Pwnage1337
Pwnage1337's Avatar
I've been looking at mine and was pretty sure it was going to need some persuading to fit lol
Old 10-04-2017, 01:27 AM
  #44
Pwnage1337
Pwnage1337's Avatar
Got my cooler lines all built and ready to go. Taking the DS for shortening tomorrow, will run the TCU wiring while waiting for it to get finished.
Here's a picture of some sexy guy I know
Old 10-05-2017, 03:18 PM
  #45
Pwnage1337
Pwnage1337's Avatar
It's in the car, hanging all by itself. Only drilled up the one hole and ran the bolt through finger tight, to check for clearance to the Yoke. I got about 3/8" clearance, so I think I'm home free!
TCU is installed, with the exception of the 2 switches for Full manual and performance/normal mode (shift aggression)
The cardboard is there to hold the C-beam away from the tunnel. Hard to keep this all lined up and keep **** straight.
Right now it appears that one of my biggest difficulties is going to get the dipstick in. LOL
Old 10-05-2017, 09:29 PM
  #46
1993C4LT1
1993C4LT1's Avatar
Lol at the pic!! Dude you've made good, quick progress on the swap.
Old 10-05-2017, 09:48 PM
  #47
Pwnage1337
Pwnage1337's Avatar
I hate doing **** like this because I'm already thinking of how I would've done it differently if I had to do it again.
I fought the dipstick for about an hour and a half, finally got that situated. Started mocking up the linkage and had to shorten the shift shaft on the transmission, as it was in direct path of the exhaust. Just got that finished up right now!
Putting the pan back on the trans next, then putting the exhaust back on. It's rainy here so maiden voyage won't be too wild because of wet roads.
Old 10-06-2017, 03:03 PM
  #48
Pwnage1337
Pwnage1337's Avatar
You can hear my sweet exhaust leak under the car! I didn't get around to replacing the band clamps with V-bands.
I scared the living **** out of myself when first starting it up. I filled the pan, cranked it, and while cranking was getting a dull thud/clunk. Very disheartening, but then read online that its probably because the trans is dry.
I proceeded to start the car and fill the entire trans and the sound went away. Scared the **** out of me.
Old 10-06-2017, 06:49 PM
  #49
Pwnage1337
Pwnage1337's Avatar
Maiden Voyage of the car was a success! Totally different animal. Love the 1/2 Gear shift, I haven't wired the toggles for performance/normal yet.
Have a little work to do with the linkage also. P/R/N are okay, but when i move to OD, the car can't decide if its in D or OD.
Also not sure if my cooler is big enough. It's a pretty cool day today, and temp got up to 190 pretty quick. Cooler is 180 on 165 off. It basically held temps at 190, but I was hitting it pretty hard.
Old 10-06-2017, 08:20 PM
  #50
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Great job. Congratulations.
Old 10-06-2017, 10:09 PM
  #51
Pwnage1337
Pwnage1337's Avatar
I will say, totally different car with the 3200 stall. The 40 mph throttle stomps produce instant tire smoke on street tire until you let off. Neighbors absolutely do not approve
The following 2 users liked this post by Pwnage1337:
Bobo Greybeard (04-01-2018), knikula (10-11-2017)
Old 10-06-2017, 10:18 PM
  #52
pologreen1
pologreen1's Avatar
Awesome! You have come a long way with that car,
Old 10-07-2017, 12:38 AM
  #53
Pwnage1337
Pwnage1337's Avatar
Thanks. We're growing up together LOL. I've had it for exactly 9 years today. Bought it just before my 17th birthday.
It's been a long road, few more things I want to sort out before painting it and doing weatherstripping. Trying to get all the mechanical stuff sorted out before doing cosmetic stuff.
Old 10-07-2017, 01:35 PM
  #54
383vett
383vett's Avatar
Good job. That tranny should outlive the car.
Old 10-07-2017, 07:02 PM
  #55
Pwnage1337
Pwnage1337's Avatar
I'm figuring out the tuning on this thing a little at a time. Initially I had set shift firmness too high which is a direct driver of line pressure. I had too much line pressure in first gear and it was wanting to snub the car out.
Still need to wire the switch for performance mode, and figure out the speedo.
Old 10-07-2017, 11:27 PM
  #56
1993C4LT1
1993C4LT1's Avatar
You'll get it sorted out
Cool that you've owned the car since 16
Old 10-07-2017, 11:36 PM
  #57
Pwnage1337
Pwnage1337's Avatar
Speedo has me baffled.
There is conflicting information on the internet, imagine that.
The EZ TCU outputs a square wave, with the ability to select how many PPM you want it to output.
From my understanding, the digidash took the signal from the VSS, which was 4000 PPM sine wave, converted it to square wave at 2000 ppm, then sent it to the ECM
So somehow I need to convert my square wave to sine wave so I can send it to the dash.
...I think
To 4L80E Swap - Let the Games begin
Old 03-30-2018, 08:37 PM
  #58
Pwnage1337
Pwnage1337's Avatar
For anyone who may have been following this:
I was able to get my speedo functional by using a Dakota Digital SGI-5E. (Right Part #??)
Anywho, I used the one wire speedo output from my transmission controller, fed it into the SGI5-E then hooked it up to the cluster wiring that resides in the passenger side footwell. There are two wires for the digidash speedo, purple and yellow. I spliced into the purple wire, and set the SGI-5E to a 2x multiplication to convert the signal to from the EZ TCU to sine wave, digidash speedo functional!
GPS Accurate up to 130 (verified)
If anyone wants more info/pics I can provide. Car is down right now for a steering rack rebuild anyways.
Red 91 (04-01-2018)
Old 03-31-2018, 07:23 AM
  #59
bjankuski
bjankuski's Avatar
Very nice build.
Old 03-31-2018, 01:27 PM
  #60
383vett
383vett's Avatar
Good job!
Quick Reply: 4L80E Swap - Let the Games begin
