Differences in the 1989-1991 L98
Hello. I am looking to purchase an L98 for a project I'm working on and I have two motors I am looking at an 89 and an 91. From what I have seen the 89 is MAF, slightly bigger cam, and the heads are different. Is there any benefit with going in with the 89 over the 91 or 91 over the 89? Any help would be appreciated.
Speed density is harder to work with when mods come in since it doesn't adjust as well. That said, once set up, life is good. What do you want this car to do? If you are building it and trying different mods, I'd go MAF. If you are doing a "set it and forget it", I'd go SD.
Why? With the L98 intake, you are hobbling yourself. Also cam changes would be only SOTP, or as I like to call it, imaginary. I'd do intakes, headers cam and fluff the heads. After that, dyno tuning.
Pro Mechanic
Say what? Cam is the single biggest change you can make to a motor, other than forced induction. One car I had, I did a cam & lifter ONLY swap, and dropped a second off my 1/4 mile time. No other single part will do that -especially for the price.
How did you get a second without the ECM being tweaked? I did intake and headers and it ran but never right. My 74219 cam would run but not smoothly when we had the stock intake on.
Pro Mechanic
It was an '83 TA so it had a feed back carb. It still had a speed density system to fine tune the primary side of the carb...but with no tuning at all; jets or chips, it ran fine and went 1 sec faster.
For sure a speed density car could use a tune after a cam swap like that one.
I would imagine so unless the cam is close to the OEM which is a waste of resources.
Right now I'm looking for a motor and of the two I have in mind ones an 89 and the other is a 91. Let's leave the MAF/SD, and cam arguments out of the equation. Are the pistons the only difference between the years of the motors? I have been looking at 1/4 mile times and the 89's and 90/91's run about the same with smaller gears. Are the 90/91's underrated?
If you had an LG4 I can see that easily happening.
It's possible. He didn't mention if it was an LG4 or L69. If it's an L69 I don't see it. The L69 had an aggressive cam ( I dont have the specs in front of me but it was more aggressive than the L83 cam and it might even be bigger than the 85-87 L98 cam) in it and if I remember correctly an L69 car ran mid 15's and an LG4 car ran high 16's on a good run. L69's also had freer flowing exhaust, 3.73's and the Trans Am had the "ram air" scoop that ducts the air into the air cleaner. If I remember correctly this "ram air" was part of the WS6 package so it also came on the LG4. The L69 package is good for ~1.5 seconds. What would the cam alone do? He didn't mention any cam specs either.
Pro Mechanic
It was and LG4. The cam swapped in was not big. IIRC it was in the 2-low teens range. 212/218ish? Still idled like stock, still got stock like gas mileage.
Results could easily be reproduced. Wait...*I* reproduced that result in a LU5 (CFI) TA, years later.
How many other "GM guy cam only lines" are there?
Pro Mechanic
You're right that the LG4 came with the cowl hood. All LG4, LU5, and L69 Trans Am's had that hood. Some Camaro's had a cold air hood too, but I THINK on those it was only on LU5's and L69's.
Those a great times for an LG4.
In 1982-1983 LU5 Camaro's had a fiberglass hood with functional flaps. I am not sure if in 83 all Z28's had fiberglass hoods on them and they switched to steel in 84. L69 Camaro's had the dual snorkel air cleaner with the giant ducts and the hood flaps were non functional. In 85 both the IROC and TA had the dual snorkel air cleaner on the L69. They supposedly made some L69's in 1986 but as far as I know those are unicorn cars.
Pro Mechanic
Thanks. I was pretty embarrassed by the stock 1/4 mile times, but pretty proud of the change from the cam. Back then, darn "fast" street cars were running 13's, so what ever LG4's should have run, I knew that 16.1 wasn't very good.
Huh....I have yet to see an L69 TA with a dual snorkel air cleaner. Every one that I have seen had the single w/the cowl hood, like this:
I guess an '85 would have dual snorkel b/c they didn't have the cowl hood anymore, after '84.
In 85 they used the same air cleaner as the camaro. 85 L69's are rare especially trans ams. There was an L69 Recaro on ebay about a month ago. They pop up from time to time.
Enjoy!
