self-aligning rocker arms vs. adjustable pushrod guides? - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Reload this Page >
Old 10-07-2017, 10:56 PM
ryank9398
CF Senior Member
ryank9398's Avatar
Default self-aligning rocker arms vs. adjustable pushrod guides?
I'm rebuilding my motor with AFR heads and Comp 268XFI roller. The heads came with adjustable guide plates. I previously had full roller self-aligning rocker arms in 1.6 ratio, part number 555-20145 from Jegs. I saw in the instructions that the guide plates were not compatible with self-aligning rockers. Forgive my ignorance, but why not? Pictures of mockup:
ryank9398 is offline
Old 10-08-2017, 12:04 AM
383vett
CF Senior Member
383vett's Avatar
You use one or the other, not both. The guideplate might want to push the pushrod past the aligning retainer. Bad things will then happen.
383vett is offline
The Following User Says Thank You to 383vett For This Useful Post:
ryank9398 (10-09-2017)
Old 10-09-2017, 10:18 PM
ryank9398
CF Senior Member
ryank9398's Avatar
Thanks 383Vett.
So I took the guide plates off and was able to get this marking on the pushrods. I didn't have the head torqued down. Never done this before, is my procedure correct and is this result ok?
Old 10-10-2017, 05:41 AM
gerardvg
CF Senior Member
gerardvg's Avatar
Been there done that with a previous car, had a professional engine builder put together a high performance 351 cleveland engine.
Around a week later clanking noises......... turned out he forgot you need hardened push rods with guide plates ......oil was full of shiny metal flakes.
The engine spun well over 8,500 rpm .... sounded awsome ... then after 3 months BANG a valve retainer collet's failed to do with wear and roller rocker geometry ....
Yes high RPM sounds fantastic but wear is shocking, new lesson replace collets every 2 months and pushrod length is critical.
Needless to say my 383 has forged Crank Rods and forged pistons but fairly mild camshaft running standard rockers..
There is no sweeter sound than a V8 revving to 8,500 rpm....... but i am once bitten twice shy. Am happy with a blower and low rpm hp torque , should last many many years
gerardvg is offline
Old 10-10-2017, 08:13 AM
Kubs
CF Senior Member
Kubs's Avatar
St. Jude Donor '09-'10-'11
Originally Posted by ryank9398 View Post
Thanks 383Vett.
What procedure did you use? Did you use a solid lifter or a really weak checker spring to make sure you're not collapsing the lifter while taking measurements? Did you measure with an adjustable pushrod?
Looks like your pushrods are a tad too long.
Kubs is offline
Old 10-10-2017, 03:03 PM
rklessdriver
CF Senior Member
rklessdriver's Avatar
Normally you would want to pick either SA rockers of guide plates..... but on this combo you can actually run both with no issues....
The AFR heads with the 8mm valve stems won't positively align the SA rockers because the distance between the "guide wings" on the rocker is set up for 11/32 valves (.343) the 8mm stem (.315) this will allow the rocker to slide back and forth .028" ..... this is too much play to properly align the rocker arm and the rocker arms will come off the valve stems when actually running at higher RPM.
The normal interference that occurs when trying to use both SA rockers and guide plates won't happen because as I said there is plenty of rocker arm "wiggle room" (.028') on the valve stem so the guide plate will actually do all the aligning.
Will
rklessdriver is offline
The Following User Says Thank You to rklessdriver For This Useful Post:
ryank9398 (11-09-2017)
Old 10-10-2017, 04:42 PM
bjankuski
CF Senior Member
My 1987 GTA actually came from the factory with self aligning rockers arms and the pushrod guides in the cast iron heads. It worked fine since both of them were lined up correctly. the car had over 100,000 miles on it with no issue.
bjankuski is offline
Old 11-10-2017, 12:01 AM
ryank9398
CF Senior Member
ryank9398's Avatar
Will
Thank you very much, this makes sense to me. I have been setting this up with a bunch of feeler gauges, trying to set lash with clearance between the valve stem and the pushrod guides.
By the way, what do you think of my rocker geometry/pushrod length?
Old 11-10-2017, 07:43 PM
rklessdriver
CF Senior Member
Your pattern on the valve stem looks fine. However, the pushrod measurement you end up with will be too long because the valve springs will bottom the hyd lifter out when checking and when the engine is actually running the lifter plunger will rise and move the rocker to a point further towards the exhaust side of the valve tip as well increasing the width of the pattern.
You need to figure out how much the lifter plunger is collasping and subtract that from your pushrod measurement.
Or redo the pattern with light checker springs... or take an old lifter, dissasemble the plunger assembly and shim it upunder the cup to act as a soild lifter.
Will
Quick Reply: self-aligning rocker arms vs. adjustable pushrod guides?
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
