Rear ride height adjustment- is it that easy?
Zen Vet Master Level VII
So with my driver side lower than the passenger, I need to spin the nut up on the driver side and spin the nut lower the nut on the passenger-- pretty much mirroring your set up?
Thanks!
Here's what I had to deal with.
driver
passenger
Don't know how long this has been going on. 88 has not been a regular on the roads as I am doing a frame on resto but taking several years to complete it. I am doing body work now and will prime after.
driver
passenger
Huh, I might give it another shot before taking it in. Both nuts are perfect on the hole/cotter pin hole so your recommendation is only 3/4 of and inch on each bolt; I have plenty of room and will double bolt for good measure.
Thanks!
Thanks!
Wow, this is perfect as it give me an idea on what to do- my situation looks similar.
Well, I just took a stab at it and really did not make much of a difference. I raised the drivers side nut all the way and lowered the passenger side as far as I could safely. After taking it around the block it only improved the gap 2mm.
I did the math and I'll need a much longer bolt than I have!
I have an appointment for Thursday. I think that this is way too much geometry for me,
**UPDATE**
I had Jim at Mid Cities in Hurst look at it. He said that he was able to get the front to 1/8 and the rear to 3/8 difference. He messed with the bolt/nut height, flipped the spring and adjust the cam. I pick it up this afternoon so I'll be doing some measuring when I get her home!
