Low speed noise
Low speed noise
Hi everyone,
I am looking into a C4 1986 with a standard and 350. It’s sat for two years but has been started everyday. Tires don’t even have dry rot. However when test driving it, it had a low speed knock feel to it. But as soon as I go in on the clutch it goes away. If I speed up some it goes away. But anything under 5 or 10 mph not on clutch in first does it. It may just be my bad driving. Been a minute since I’ve driven a standard. But any help would be appreciated
Zen Vet Master Level VII
Not much information to go on but from what you said, you may have developed some flat spots on your tires.
Started everyday? Serious? If the previous owner really started and let the car idle, without driving it every day for two years, you need to spend some time with the engine. That is not good for it.
And yes yes they would drive it short distances. Maybe less than three miles. Engine sounds as strong as my old tpi. I don’t believe they just let it idle but if they didn’t drive it. They’d start it for a short time and shut it off. Just to move fluids around
