Exhaust Drone!
#161
Pro Mechanic
Its called an electric cut-out. And yes I adjust it based on performance needs. With a half-open cutout there is certainly an improvement to torque from idle to around 4000rpm on my previous vehicle, which was turbo. It would remove around half of the turbo lag when stabbing the pedal from a highway cruise as well when partially closed.
You used the reliable "peel-o-meter" to measure your 1/2 open cut out gains? Or the good 'ol "butt-o-meter"? This stuff puts our friend Phoenix to shame.
GREGGPENN (01-11-2018)
#162
The implication being that you are capable of teaching. My Yelp review will indicate otherwise.
#163
https://www.corvetteforum.com/forums...ml#post1703136
For: "This is the primary paradox of exhaust flow dynamics and the solution is usually a design compromise that produces an acceptable amount of throttle response, torque and horsepower across the entire powerband. "
I suggest using a cut-out to this end.
"A very common mistake made by some performance people is the selection of exhaust headers with primary tubes that are too large in diameter for their engine's state of tune. Bigger is not necessarily better and is often worse."
And...after doing so, offset it with a partially open cutout. Makes perfect sense! You, sir, are a genius!
#164
I completely agree with this:
Quote:
For virtually all high performance purposes, backpressure in an exhaust system increases engine-pumping losses and decreases available engine power. It is true that some engines are mechanically tuned to "X" amount of backpressure and can show a loss of low-end torque when that backpressure is reduced. It is also true that the same engine that lost low-end torque with reduced back-pressure can be mechanically re-tuned to show an increase of low-end torque with the same reduction of back-pressure. More importantly, maximum mid-to-high RPM power will be achieved with the lowest possible backpressure. Period!
As for the rest of that quote of yours, you continue to conflate gas velocity in a primary tube with backpressure. The two are not only not the same, but they are (in this context) almost diametrically opposed! As I've already explained, increased gas velocity in a header primary will actually lower backpressure on the valve in a certain rpm range. In that range, it improves power output. At a higher rpm, where backpressure overwhelms the negative-pressure phase acting on the valve, it decreases power. Again, even in a primary tube, there is never a time when increased backpressure (i.e., reducing the pressure gradient across a system) will improve output (VE, torque, power...however you want to put it).
Exhaust gas pressure by itself is meaningless;
It can be 0psi or 15psi or 30psi and the engine could run absolutely fine or like total trash.
Another way to see it is, if you can prove to yourself that occasionally a decrease in backpressure is met with a decrease in engine output (torque), then how can you possible correlate a decrease in exhaust gas pressure with an increase in output (torque)? Just because you feel like it? It doesn't work that way.
You have been asked at least five times to show the data to support your claim that decreasing backpressure can decrease power. You haven't done so. Again, stop posting unsupported claims here. Post your data or STFU.
#165
In a desperate attempt to get this back on target lets look at this logically all SBC do not drone. Do any other cars that do not drone have 2 manifolds to Y-pipe to central cat then branch back out to dual exhaust drone? If no what is different with the body? Do cars with duals from engine to exhaust tips drone in any chassis and if only C4 then what is different with the body?
Kingtal0n please do not reply as you are where 90% of this went off track and a worthy thing to solve for all. You offered 0 useful information other than beer goggles full engineering.
#166
Pro Mechanic
#167
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
#168
I've been a in a lot of different American V8 cars that droned, including F-bodies and lots of Mustangs (different firing order there, too) and one 2005 GTO with Kooks headers and I-don't-know-what exhaust. So it isn't unique to C4s. My guess is that any engine on any car could drone if the exhaust is the right length and diameter. By extension, probably every system out there can drone a bit at some rpm, but the general length of pony-car exhausts and the firing spacing and number on a cross-plane V8 makes it likely that the drone will be focused in the cruising range of rpms, and that it will be especially obnoxious in tone. Back in the 1960s, when muscle cars had top gears of 1:1 and gear ratios in the high 3s and 4s, nobody noticed because everyone cruised around at 3500rpm or more. The quarter-wave resonator is probably the best way to address it, and of course the quieter the exhaust is overall and/or the more the cabin is insulated from the exhaust sound, the less loud it will be.
#170
So conclusion: The best exhaust is one which would increase in flow while maintaining the same velocity as engine RPM increases. Pretty sure thats what I said in the first post.
#171
my favorite part. I am not sure you realize this but the question is regarding measuring a pressure without any reference. It's like you yourself have forgotten that the pressure on our gauge is useless without having an atmosphere to sample.
#172
It was okay when you said this the first time, because we all say wrong things sometimes. But those of us with more clue than attitude are happy to be corrected and learn the errors of our ways. I have tried to elicit your understanding of why this is wrong multiple times, with a question to lead you to the knowledge: what is PSIA vs PSIG? If you weren't so intent on being a smug, dumb, ******* to all of us, you'd have looked that up by now. You'd have found that one is "pounds per square inch absolute" and the other is "pounds per square inch gauge." And you'd now know that PSIG is, by definition, a pressure measurement referenced to atmospheric pressure (which is why the gauge always reads "zero" when it isn't measuring anything). And you would now understand that the gauge you use to measure exhaust pressure most certainly does reference atmospheric pressure.
Tom400CFI (01-11-2018)
#173
Pro Mechanic
Edit for this: I LOVE ^this post. LOVE IT. That is hitting the nail squarely on the head.
I never questioned the existence of exhaust cut outs...our 1910 Hupmobile has that..."technology". What I DID say was...ah, never mind. These Huckabee/Conway arguments are pointless.
But I can say this...when I close the exhaust cut out on the '10 Hup? OMG, the thing turns into a LOW RPM TOWAK MONSTAH!!! Have you let Phoenix know about this Tork Tuning Secret? Maybe his car could climb "inclines" on the highway if he installs a exhaust cut out so he can close it?
#174
Yes, and that is wrong. It was wrong in your first post and it's wrong now.
I have literally never typed this to anyone before, ever: you are one dumb ************. You are so dumb you don't even understand that you are dumb. And worse yet, you have a smug and self-righteous attitude about the dumb crap that you continue to spew into this thread.
ANY engine,
and I install an exhaust system with an increasing diameter, set to increase as RPM rises, thus maintaining some superior velocity throughout the rev range.
That I wouldn't make more torque throughout the rev range?
Just making sure
Obviously: "Exhaust system" includes all part of the exhaust from head to tail.
#175
Oh so lets all be clear. You are telling me that if I have an engine,
ANY engine,
Just making sure
ANY engine,
Just making sure
EDIT:
#176
SO what do you think this author means by,
compromise? What is it we are compromising and how is "acceptable across the powerband" based on our exhaust system?
#177
And you are saying that if I have this
On an engine by itself, with no exhaust system, that it will produce more torque and horsepower throughout the rev range than with an exhaust to collect and gather the hot gas molecules to flow together for a distance?
You must see how this is ludicrous. Yet this is what you insist.
edit: I think I see the error. You are assuming that the collector and anything before a collector (header) is not part of the exhaust system. And then in your mind, the collector is actually after a long series of exhaust tubes, tuned to performance already. Well my friend this is part of the exhaust system, and if removing whatever comes after improves performance it is because the exhaust system is well designed leading up to the collector.
#178
This is a stock 5.3L truck manifold
I have dozens of these.
So if I put them on a stock 5.3 and dyno the car open collector.
And then add an exhaust system between 2" and 2.5" diameter.
The engine will lose torque with the exhaust system installed?
Just to be clear again
Here is something Showing smaller diameter exhaust tube is increasing torque from idle to midrange. It was a random search, I am sure there are many many others like it. How many do you want me to find?
https://www.sandersonheaders.com/let...technical.html
#179
I would also suggest "retuning" a drone problem by purposely changing to a different (probably smaller) bodied muffler....or move "back" to no muffler, a good "H"/"X" and cats before trying another type of muffler.
If that doesn't work, it seems "we" have already eliminated all box-style mufflers EXCEPT Corsa and the Magnaflow x-muffler series.
As for shape of the car, I doubt drone is unique to the C4...though if it varies somewhat, I'd look to a combination of the F40 shape AND that it's an open hatchback. ANY vehicle with an open cargo area transmits tons more "road/exhaust" noise IMO.
#180
How did we get from stating: an engine -- with a properly designed header -- doesn't need downstream piping
-- to --
posting a picture of a poorly designed bum-fkd MANIFOLD (with non-existent primaries) that NEEDS some kind of pipe just to serve as a bastard secondary collector
while concluding that a HEADER PRIMARY SIZING chart has ANYTHING to do with exhaust pipe selection?
Once again....BRILLIANT!
