Delete the Egr and crossover tube
So my cross over tube for the egr has cracked! I have a 1986 corvette with a l31 vortect 350 with the special tpi intake so all the corvette stuff fits. The ones im finding on ebay look rough im wondering what it takes to delete the egr tube. I had PCM forless tune my chip for when i got this engine originally and it runs great but its throwing code 44 and i bet its cause that pipe is leaking exhaust. Thoughts ideas?
Code 44 is an AFR code. That's caused by O2 sensor problems. In '86 the O2 sensor is on the driver's side, so anything that happens on the passenger side is not a factor in this situation. You would have to leak a LOT of exhaust for it to affect the engine operation. You're much more likely to have the O2 sensor wiring shorted to ground.
JrRifleCoach (12-25-2017)
