Can you drive a 92 without the gauge cluster?
Is it possible to drive a 92 coupe without the gauge cluster for a couple of weeks?
I'm a new owner of a 92 coupe, using it as a daily driver.. Love the car, my first corvette. The tach went out, and the oil and water temp gauges read far under. I was considering sending it in for repair at a service advertised on ebay, but I have to keep the car drivable.
thanks!
thanks!
http://www.batee.com/
Use this guy. I have, good service, honest. Many in here have and I cant remember one person complaining. Sure, why not drive it, but put it back in asap. PUT YOU HEADLIGHT **** AND RETainer in a plastic bag. Its gets lost easialy. Sorry about the caps
thanks!
thanks!
Explain what you mean by "tach went out"? Do you mean it's just inaccurate or doesn't function at all. When you turn the ignition to RUN before cranking the engine does the tach park at 0? With key off and in your pocket the tach will park randomly NEAR 0 but with KEY ON not running it should park at 0.
I say send it nowhere yet!!
Zen Vet Master Level VII
Go buy a junk yard cluster ($50) and swap it in while you have your original rebuilt. You will have a road worthy car and no worries of electrical problems.
Yes, theoretically you can, however the risk may not be the reward. Loose connection briefly touching something after hitting a bump could short out and create LOTS of problems.
The CCM mainly connects to it and drives the cluster. Who knows what the effects may be since so many outputs will be unloaded, possibly nothing. I don't think there's much to short out since its mostly connectors. I think a lot of codes will be generated.
https://dallas.craigslist.org/ftw/pt...419107607.html
Call this guy and buy his cluster while yours gets fixed. It may be a POS but I will be better than driving with plugs and wires flopping about.
Why would you suggest a cluster that's not even compatible? I don't get it - the OP hasn't mentioned actually what's wrong with it.
Granted he's ask if he could but I believe the best move is for diagnostics 1st! I'd think maybe the fact that he's mentioned an eBay offering without actually referring to 'who'.
Easy to spend someone else's money I guess.
Loose connection on what? It's a hard plastic pin retainer mounted to the dash frame. There is no way to short something unless you are driving around with a paper clip deliberately trying to short something.
You do diagnostics before sending it to anyone! The analog gauges aren't near correct and having the cluster serviced likely won't improve the accuracy.
Research shows it's most likely a resister type IC on the board. I saw the one Batee sells and was thinking of repairing it myself. Not afraid to dig into the car, it's just a chevy, but concerned about calibrations, and if it repairs the other gauges too
Also just read about a Camaro guy who drove without his, and it killed his alternator. The lack of a amp gauge being attached did something to it I guess. This is the first computer controlled car I've owned, so it's new territory for me.
You can drive it around if you want to. Don't let anything metal touch the terminals of the connector. Drive it around all you want. You wont have an odometer or a fuel gauge.
This is sound advice. Nothing is going to happen. Lots of advice from people who have never had one apart.
