Merry Xmas tranny pull
im trying to get my transmission out today and can not figure out how to remove or disconnect the TV Cable. 1993 lt1 auto, do I have to drop the pan?
Got it! had to unhook it from the asr first then from underneath. Now can I leave the torque converter on the flex plate or do I have to remove those bolts before the bellhousing bolts?
^^^ This.
You can leave it on the flexplate, but you'll dump about a gallon and a half of trans fluid on the floor and you will never be able to get it lined back up to install.
Absolutely rotate the engine and remove the flexplate bolts before proceeding.
Thanks for the advice confab and 81c3! I will be sure to remove those bolts tomorrow. is it just me or is it a PITA that the inspection cover goes around the starter without a slot to remove it, without taking out the starter... so I have to take the starter off to remove the cover but put it back to turn the motor over to get my bolts?
I agree with the others, turn the engine by hand. Do not use the starter. I take a pointy pry bar and just shove them around, but any of the methods mentioned above will work fine.
Be sure to disconnect the battery!!!!
