What is the cheapest/most reasonable route to this sound
That's what I thought. But now was it really 30 years or just enough time to get their money worth out of the tooling?
Back to the op. But seriously the turbo mufflers actually remind me of flow masters which I only like on certain cars. I never really liked magnaflows either until I heard my uncle's 400 67 firebird. You hear it ad literally feel the ground thump. Shakes the whole damn house too. No matter what you do, if you don't do a cam swap to some similar cam you won't get that sound. Headers and muffler will get you the loudness and rasp but the cam defines the total sound. Throaty, deep etc. In my opinion don't change just for sound. Throw on a set of cutouts or remove the mufflers and see how you like that first then do cutouts. It may get you in your ballpark. You never know. Try the free things first.
I figure cam first and take it from there. No point in doing anything really until the cam is done. I just dont know how driveable it will be with a cam that lifts as high as that one does. I guess thats why I started this thread but it just didnt go in the direction I anticipated.. anyway, thanks for all the advise.
What are your goals for swapping the cam? Comp has some videos on their site with some of their available cams. You could see what you like there and cross check on youtube. Don't do it just for sound is all I'm saying.
I just listened to the video, that actually does sound very good to me as well. You're obviously going to need a cam to get that rumpty-rump idle. The deep idle tone is likely largely a product of the long tubes. When he revs it you get that higher pitched exotic tone, that'd be coming from the X pipe. If you want that exact sound you'd need to duplicate what he did completely. If you want to try to skip the long tubes I'd probably say do the cam and X Pipe and then you'd need to experiment with either muffler eliminators or possibly the turbo mufflers to see if you can get close to it.
I am actually surprised that the car in the video has as lumpy an idle as it does with just a Hot Cam. Maybe he has the idle as low as stock. I have considerably more overlap, but mine idles around 1000rpm to make sure it stays happy.
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
.....Another thing I did was add the Blockit sound deadening mats to the rear hatch area. These things actually work well to attenuate the wind and road noise so that the exhaust sound comes through. I am surprised how well they work for this and it was unexpected.
My car is an 89 with the L98 engine, so your video of an LT1 may not apply.
I agree with all of this. My car has long-tubes followed by a custom 3" exhaust with good aftermarket cats, an X-pipe, and then Corsa mufflers at the back. That rasp when he revs it is definitely provided by the X-pipe. I get compliments on the sound of my car pretty frequently.
my 2 cents worth, just to muddy the thread up a bit (also I don't have speakers on this computer right now), but the sound of a built 327 through side pipes. that is my holy grail, ranking right equally next to a big block through headers, either mopar or chevy.
He explains some in the youtube comments
gyro9
5 years ago I started modding. I did the HotCam kit, which included the 1.6:1 roller rockers. Then, I replaced the stock exhaust headers with Stainless Works long tube headers. In addition, I replaced the original catalytic convertors with Random Tech high-flow bullet cats and replaced the resonator with a MagnaFlow stainless steel X-pipe. This winter, I installed new mufflers, the HOT (high output turbo) mufflers from CorvetteCentral.
For the HotCam, parts and labor came to about $1250. Total mods in the car now total about $7K.
When asked if he pulled the motor:
No, the motor wasn't pulled out, just lifted in front with a jack from below after loosening the front engine mounting bolts. Only the radiator and A/C heat exchanger were removed. Even the hood was left on.
The exhaust mods (see 'About this video' above) also had a lot to do with the sound, especially the mufflers and X-pipe.
Cam Style: Hydraulic Roller Operating Range: 1,800-5,800 RPM Advertised Duration: Intake 279 Exhaust 287 Duration @ .050: Intake 218 Exhaust 228 Lift with 1.6 Rockers: Intake .525" Exhaust .525" LSA: 112
The GM HotCam kit comes with the camshaft, 1.6 roller rockers, and valve springs. I don't recall the exact cost, but I think it was about $400. Installation was about another $1K. Before I did the headers, the cam alone didn't help very much. With only the cam, I took only 0.05 seconds off my best quarter mile time. After I did the headers, another 0.25 seconds came off. Most 'experts' recommend doing cylinder heads along with the cam, rather than doing the exhaust, for a better combination.
It's an auto. The chip that was in it during that video recording had an idle of about 800 rpm. I later replaced it with a 900 rpm idle to improve low rpm performance.
gyro9
Sorry, this is the one that got away. I had to sell it when I was a single father, raising 2 children and we needed a house to live in. Seeing as how I don't have the money to purchase another C2, I will forever be chasing
the sound.
I will look and see if I can find a youtube vid with sound of a 327. They had a sound of their own.
While the firing order and such is the same, 327's, like the 302 engine developed for road racing and sold in Camaros are revvers.
The engines that are not muffled coming through cats and such had a different sound in my opinion.
Not having sound to listen, but here is a 327 pulling a 350. If I get a chance to do another car besides my '96 (which is an A4), I would like to get a '94/'95 M6 and have a 327 crank custom ground for it. Optionally, I recently read about a LSx based 327 engine (I don't remember the x designation) that pulled some pretty strong numbers. I was shifting at 6500 rpm (held it at that redline) at just under 110mph from 2nd into 3rd. While I know that torque gets you going, a high winding engine is fun.
the sound.
#33
#34
C4 of Year Finalist (appearance mods) 2019
So to go to the OP's original posted question..... the cheapest/most reasonable route to get to HIS desired sound.
I don't think that there is an inexpensive way to get there.
IMHO long tube headers are the most significant improvement you can make towards getting the lower rumble. That's originally why I got my Stainless Works header setup. I just loved the difference in the sound that one change made......... and headers alone won't require a re-tune on an LT1.
But to make the sound sweet you need a little lope and (again IMHO) you can't go wrong with the Hot Cam Kit ... although I think it now goes for quite a bit more than when the previous poster installed his kit. The nice thing about the kit is that if your not an expert all the parts are matched to perform properly with each other. Note my heads are stock.
To get the most out of the cam swap however you will need to have a tune done to the car. Back when I had this done ....... 70,000 miles ago ... I think I gained around 40+ RWHP on a mustang dyno. Mine was intentionally set to idle high around 700 - 800 for driveablity issues in bumper to bumper rush hour traffic.
I think my car sounds wonderful..... and while it wasn't inexpensive I'm still driving it briskly .. now with 135K on it
#35
I cant help but assume you did more right off the bat though than just do your headers? Surely you changed your exhaust downstream?
I just cant seem to find anyone who left the stock exhaust in place and did the cats.. or left the stock exhaust alone and did LT headers.. but cant help but wonder what those to might sound like.
I did a lot of reading last night about exhaust systems and power and now am scared to death to touch mine which is 100% factory with no rust on it.
that being said, yesterday, in a cabin fever moment, I started her up with the garage doors shut. its sounded like a soccer mom mini van. IT HAS TO GO..
Im scared to death to mess with my unmolested 73k miles 96 but life is short. Im going get a few quotes on the hot cam install.. perhaps today whilst "working".
A few questions:
If headers are the key to the sound; how do I choose a set?
How do I choose a header back exhaust that works well with a cam?
What would the result be if I ran my stock exhaust be with headers, and perhaps no cats and a cam? Would it be too quiet?
How driveable is that car in the video I posted? Would I need to mess with the torque converter??
Would low end torque be hurt badly? Should I abandon this and go straight for rear end gear for now?
Anyone know where I can get a tune for a 96? what is involved? Is that a physical chip or a laptop upload?
thanks
#36
If the visual test is not a problem, you can get plain headers, but they still need to have bungs for the pre-cat 02 sensors (car won't run right without those!). The bungs can be easily enough added by a shop, if they don't come that way. I'd review a few threads about different options - I don't know which are the best fitting and quality. I have Hookers on mine and they fit and work very well.
BTW, whether you have the AIR system and cats installed or not, you may need to turn off the after-cat O2 sensors. They will be considerably further from the engine and may not work properly, even if they are installed and plugged in.
thanks
thanks
#37
For whatever this is worth, I did this with my old 89 Mustang, but I used an H-pipe with high performance cats. It sounded better than stock, a bit louder (but not much), with a nice burble. It wasn't close to that Corvette in the video, though. You'd probably like the improvement, but the raspy bark at high rpms won't be there. That really only comes from using an X-pipe. You could put one in place of your center resonator, which along with headers would really make a difference. Basically, you need to find a C4 that has long-tube headers but the stock cam to learn what it sounds like, and then go from there.
Definitely don't throw away whatever you remove. Store it in the attic or basement.
The first question you need to answer is whether or not you have to pass an emissions inspection where you live. If so, do they just plug the car into a scanner and look for trouble codes? Or do they do a visual inspection? If the latter, you need headers that have fittings for the AIR tubes to connect. You can make the car pass the scan test without AIR hooked up, but it won't pass if they visually look for the system to be in place and connected. Same thing goes for cats, btw.
Really, after the headers you just want the most free-flowing exhaust possible, where performance is concerned. The other thing you have to consider regarding emissions testing is whether to use cats again or not. You can't pass a visual inspection without them, but you can make the car pass the scan. If you need to pass the visual exam, you will want a system that has cats in it. This is by no means the end of the world for performance. I have cats on mine, and it's loud and sounds awesome.
It's probably still pretty good on drivability. You'll definitely want the idle closer to 1000rpm. I bet you can get away with the stock t/c - the C4s always seemed to have a little higher stall speed than other auto cars. You would definitely benefit from a looser one, if you ever wanted to up your game.
It will be a little less, but not as big a hit as some will have you believe. It's all a matter of degrees: if you have a 2/73 rear gear now, you would benefit from a shorter gear, but you can run the stock gear if you want.
Changes in tune are done by uploading a new binary file to the PCM, not with chips. The 96 cars are the first and only year of C4s with full OBD2. As such, there is only one software package now that will work with them, called Jet DST. It's not cheap, but it works well. You can do this yourself, if you're willing to invest the time to learn what changes to make. Or you can work with the guy at http://www.lt1pcmtuning.com/. With straighforward changes like headers and a Hot Cam, he probably has a very set of calibrations for you. The PCM calibrations is also where you turn off the tests for the AIR system and the downstream O2 sensors, if you need to do that.
This is great! thank you. Now I just need to put together a project plan with implementation path and costs.
I have a horrible gear in my car.. its a 2.56 I think.. or 2.54? Per the 96 spec I can find.. I have not rotated the wheels and counted the driveshaft turns to verify yet.. maybe next weekend..
Since sound/low end torque are my goals I may start with the exhaust and go from there.. only because it will give me a little instant gratification.. but its seams this is a package deal and aint gonna be cheap.
From a cost stand point I may never get there but at least I can dream.
#38
#39
Thanks this is helpful. I dont mean to sound mean but this is the difference between an armchair quarterback and the real deal.
#40
Just found this discussion on exhaust sounds as well:
https://www.corvetteforum.com/forums...are-yours.html
