Help - 91 C4 does not want to go - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 01-12-2018, 03:53 PM   #21
aklim
CF Senior Member
aklim's Avatar
Quote:
Originally Posted by wdsj View Post
Checked data with turner pro (version 4, I can't get version 5 to stay connected to my car)
Car has not run in days and coolant temp is reading 152 C. not good
TPS has no output. Stays at 0% then starts bouncing around. not good
added: is there a different temp sensor that sends temp signal to ecu vs the dash gauge? dash gauge shows temperature ok
IIRC there is the temp sensor under the TB that sends data to the ECM. There is another one in the head that sends info to the gauge. Higher engine temp, lower resistance. If you jumper the sensor pigtail, you should get 0 ohms which means your ECM sees a lot of heat from the engine and adjusts the fuel air mixture accordingly lean. If you have a lot of resistance, the engine is thought to be cold and more fuel is added.
aklim is online now   Reply With Quote
Old 01-12-2018, 06:11 PM   #22
wdsj
CF Senior Member
wdsj's Avatar
I am not very familiar with Turner Pro, but version 4 seems to read the data.
Turner Pro indicates no output from TPS. Hand operate through full range and either reads 0 or output is erratic. I think TPS not functioning could explain my issues.
Removed the TPS and checked resistance. Ranges from approx 1 kohm to 7 and readings are smooth through full range. Sound reasonable?
No voltage detected at the TPS connector with the key ON. What voltage should be at the connector and which of the three terminals? 5V at top two terminals?
wdsj is offline   Reply With Quote
Old 01-12-2018, 06:16 PM   #23
aklim
CF Senior Member
aklim's Avatar
1 terminal should be 5V which is the reference. 2nd one should be ground. 3rd should be the signal.
https://www.autozone.com/repairinfo/...00c1528006c554
Old 01-12-2018, 06:59 PM   #24
wdsj
CF Senior Member
wdsj's Avatar
thanks, very clear information
I have nothing measurable at the TPS terminals. Appears tunerpro was correct.
any idea where this 5V comes from at the ECM? man I miss my FSM
In case its related; Tunerpro also indicated, with key to ON; no voltage at fuel pump. Key to crank, 12 volts and key back to ON maintains 12 volts.
added: TPS 5V reference at connector C c7
Old 01-12-2018, 07:56 PM   #25
wdsj
CF Senior Member
wdsj's Avatar
ECM terminal C7 reads 70mv with key ON
Do I have a bad ECM?
Old 01-16-2018, 05:39 PM   #26
wdsj
CF Senior Member
wdsj's Avatar
Monitoring fuel pump voltage; pump does not have power with key ON. Only gets power with key is on CRANK.
Voltage to pump only when key is in CRANK. Key ON after CRANK; no power.
Is there a pump relay somewhere that get bypassed when key is in CRANK?
add:
If I remember correctly, the pump only runs a few seconds when key is ON, once running the pump is sent voltage via distributor pulse; anyone confirm?
I have nothing to the TPS, checked at ECM, no reference 5V. Wouldn't the car run at idle even with 0v from the TPS?
add: Does the TPS signal have a delay? Watching scan, it appears the TPS signal comes in not long after the 5-6 seconds
Old 01-16-2018, 08:45 PM   #27
aklim
CF Senior Member
aklim's Avatar
Monitoring fuel pump voltage; pump does not have power with key ON. Only gets power with key is on CRANK. Voltage to pump only when key is in CRANK. Key ON after CRANK; no power.
Why would you expect it to have fuel pressure? You had the system primed, assuming it happened. So if you turn the key on for the first time, it primes. 2nd time within a couple minutes, it won't. That way, if you drive your car over a cliff and the engine stops, it won't keep pumping the fuel all over the hot engine.
I don't think so.
Absolutely.
Not sure. One of the 3 wires should have voltage with the KOEO.
I don't know about that. IIRC, it does NOT.
Old 01-16-2018, 09:10 PM   #28
wdsj
CF Senior Member
wdsj's Avatar
only obvious thing seems to the TPS, though I think the car should run at idle with 0 from TPS; so there is something else.
Thanks for your responses and knowledge
wdsj
Old 01-16-2018, 09:15 PM   #29
aklim
CF Senior Member
aklim's Avatar
wdsj
IDK about that. Never tried it before and mine is so not stock, I can't give you an accurate comparison. Still, the issue is that it is 0V at the reference. That is my issue. So the TPS might be perfect but here is the issue. On power on, the ECM sees a voltage it assumes to be base TPS. So, it might be confused.
Old 01-17-2018, 11:54 AM   #30
91fora93
Junior Member
91fora93's Avatar
Yeh, I still think you should be checking the fuel pump relay (see my post #8 for hypothesis on how the relay gets bypassed at crank) should be under the right side of the glove comp. carpet on the pass side. Look at this thread for reference: https://www.corvetteforum.com/forums...-location.html
91fora93 is offline   Reply With Quote
Old 01-18-2018, 03:56 PM   #31
wdsj
CF Senior Member
wdsj's Avatar
Quote:
agree, will do and let ya know.
Out of town this weekend and next week; vacation .
More to come then.
Old 01-18-2018, 08:15 PM   #32
wdsj
CF Senior Member
wdsj's Avatar
Received new (rebuilt) ECM today and I'm all packed.
Did a quick installed and engine runs great.
I guess you need that 5V reference to the TPS.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Help - 91 C4 does not want to go
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Fuel Pressure issue questions 86Pacecar C4 Tech/Performance 21 09-25-2017 09:41 PM
    C5 z06 normal oil pressures? brenbuchler C5 Tech 4 09-18-2017 12:35 PM
    low milage 1991 c4 L98 no start retiredone C4 General Discussion 18 08-23-2017 10:38 AM
    starts runs dies. skidball C4 General Discussion 1 07-19-2017 10:29 AM
    1988 Corvette stalls when hot will not start up until cools down. Isabella C4 Tech/Performance 44 10-30-2016 03:59 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
