Install of TorqHead Ltd. 24x System (Project Tilikum)
#41
I did ask a month or so ago and was told it would be something they would look into later. Problem is a lot of "look into it later" projects tend to fall off by the wayside. My usual thought is "I'll believe it when I see it.".
When I know the final amount, it will hopefully come before my L98 breaks so I have a decision as to whether to do this or get a C5 or C6 depending on the price factor. If this can make me an offer I can't refuse (engine and trans), maybe. OTOH, if it comes to within a couple grand of a C5, probably not.
#43
Personally, I prefer the looks of the C4 over the C5. If they don't have the 92-93 kit available by the end of 2019(I'll wait that long if need be), I'll probably sell my 93 convertible and buy a 94 or newer model, even if that means going back to a coupe model (targa isn't that bad).
#44
I have officially started working on it and already hitting the issues with my current modifications as usual. I am working on trying to get some videos. but just know I haven't forgotten about ya'll!
Also the argument can be made as to if this kit is worth it. I personally think for the LT1 fan club it is great and their sole market isn't just C4s. You can LS anything and to me that's part of the problem. If you want to keep your car original and be able to have more life to your tune then this maybe for you. Also I would assume like anything price will come down the more people make the purchase. Even if could be the cost of a few optis that may make it worth the price... right?
#45
Yea, any car can be LS'ed. But why would I replace my perfectly fine LT for a LS for +$5000, unless I was going for a big CiD increase, ie LSX (LSX would be significantly more), when I could make my LT just as tune-able as the LS for $2500? Honestly, I could care less about keeping it original. That's why I'm interested.
#46
#47
IMO, for $2500, IF this is plug and play and doesn't end up costing me a fortune, I could see stuffing in an LS motor if I wanted to make changes that would require tuning. Until I see the final product, I have no clue if it will be workable. I think you will have to do the mounts and if you want, might take a little work. On my L98, it will take a lot of work and nobody wants to commit to how much it will cost or they name a ridiculous sum.
luckydekko (06-26-2018)
#53
Same here! Torqhead now is aware of the challenges of this install with that hub so shouldnt be an issue for anyone elseand if so they can comment and I can walk them through it. Really minor adjustments anyways.
#54
I installed EFI Connections' 24X system in my 89 a few years ago for the same reasons as you, but they were very unhelpful and absolutely uninterested in the Y car platform.
The upgrade of the PCM is definitely worth it. Those who say its not are still surfing the web with their Commodore 64....
luckydekko (07-02-2018)
#55
Pro Mechanic
#57
I'm very excited by what I see considering I have a nice 383 ysi setup. I'll have to keep tabs on what it takes to swap out to a 94-96 harness if a 92-93 solution isn't found.
#58
good writeup!!! going to be putting a 383 into my 96 later this year and i think gm pulled their pud with the optispark so i looked at torqhead and think i will purchase this product when the time comes.
