Ground strap C4 ‘94 lt1
Old 01-15-2018, 07:51 PM
BrandanC4
Cruising
BrandanC4's Avatar
Default Ground strap C4 ‘94 lt1
Hello! Been a member for a long time. I usually find answers just searching this awesome forum. Today I tried to replace a bad body ground strap on my C4. Jacked the car up to get the bolt on the back of the engine and I can’t get the bolt undone. It’s very hard to get to even with the car jacked.
Does anyone know how to get this thing off? I think it’s a 15mm?
Old 01-15-2018, 08:06 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
Never tackled the task but I'd think if it were me I'd remove the left rear wheelhouse and do it over the frame rail. I'd think it a practical approach and a very good excuse to do the grounds on top of the frame rail beneath the battery tray.
*I assumed you're at the side of the block above the oil filter @ oil temp sensor. On an LT1 there's also a couple that are @ the converter bracket I believe and that likely wouldn't work well for those, but maybe!
Old 01-15-2018, 08:42 PM
BrandanC4
Cruising
BrandanC4's Avatar
I’m chasing the strap in this video. Idk if removing the wheel house would help
Old 01-15-2018, 08:54 PM
WVZR-1
WVZR-1's Avatar
These are the only 2 grounds LR on engine I'm familiar with.
G106 & G107 -----G101 & G102 are on the rail below the battery tray.
Old 01-15-2018, 09:01 PM
BrandanC4
Cruising
BrandanC4's Avatar
Excellent diagram. G107 is the one I’m working on. Do you have a diagram of the wheelhouse? Maybe I’m being obtuse...
To Ground strap C4 ‘94 lt1
Quick Reply: Ground strap C4 ‘94 lt1
