Green 42-Tooth Speed Sensor Gear: I Need One
Old 02-27-2018, 08:00 PM
Antarctico
Antarctico's Avatar
Default Green 42-Tooth Speed Sensor Gear: I Need One
I have a complete Dana 36 rear differential with 3.07 gears I am swapping into my Collector Edition in place of the 2.59 rear the car came with. While the correct speed sensor (p/n 10456092) is no longer available, I found an aftermarket unit that, with a wiring adapter, is advertised to work. Alternately, some forum users have suggested rotating the existing sensor (p/n 10456091) 180 degrees to allow for the different offset (relative to the drive gear) needed for speed sensor gears with more than 40 teeth. Of course, what I need, and am having trouble finding, is the green 42-tooth gear (p/n 25513049).
In the past, there were vendors and individuals who had a green gear to sell. Does anyone have a green 42-tooth gear they can part with?
Old 02-27-2018, 08:09 PM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
Try Greg @ Blower Works
I've got some 43 and 45 left I believe. Haven't looked for a while. I might actually have a 42 but I'd suggest Greg 1st!!
Antarctico (02-27-2018)
Old 02-27-2018, 08:30 PM
Antarctico
Antarctico's Avatar
Thanks! I just dropped Greg an e-mail. I'll post back once I hear from him.
Old 02-27-2018, 08:37 PM
WVZR-1
WVZR-1's Avatar
OP - you've a serious issue if your car is a '96 CE. I overlooked that.
If your car is in fact a '96 CE you've a 4L60e and it doesn't use drive/driven VSS. It uses a toothed reluctor wheel and a pickup. Calibration is done in the PCM.
I was originally responding to just your 'request'!!
What is the car really?
Old 02-27-2018, 09:09 PM
Antarctico
Antarctico's Avatar
*****! The car is a 1996 Collector Edition. So, basically, I researched myself into a blind alley, and I do not need a green 42-tooth gear.
If I hear back from Greg, I'll still post in case someone who does need a green gear might find the info useful.
Old 02-27-2018, 09:56 PM
scotth48
scotth48's Avatar
I have a 42 green but it is for a six speed manual. I got a nos one last fall as I thought it may have been bad. It was ok but I put the new one in, so have my original. If yours is an automatic that gear is available from I think if I recall it is available from ATI and you can by from them direct or from Jegs. I would have to check on the part number.
Old 02-27-2018, 10:14 PM
scotth48
scotth48's Avatar
Opps!
It was Summit not jegs.
​​​​​It is made by TCI. Part number 880030 42 tooth for automatic transmission green.
Hopefully that helps you out.
Antarctico (02-28-2018)
Old 02-28-2018, 06:54 PM
Antarctico
Antarctico's Avatar
I did hear back from Greg at BlowerWorks, and he said that he is, "pretty sure" he has the 42-tooth green gears available. So, anyone looking for a green gear should drop him an e-mail (greg at blowerworks dot net).
Old 02-28-2018, 06:59 PM
Antarctico
Antarctico's Avatar
Originally Posted by scotth48
Opps!
Yes, it does look like Summit Racing has a TCI green 42-tooth gear that will fit the pre-1994 automatic cars. That was a nice find!
To Green 42-Tooth Speed Sensor Gear: I Need One
Quick Reply: Green 42-Tooth Speed Sensor Gear: I Need One
